Author Topic: Money Money Money!  (Read 3723 times)
Offline dan23
Re: Money Money Money!
« Reply #20 on: 03 April 2008, 16:22 »
i bet hes taken it for, mot its failed and the mot sation have given him a quote for parts plus labour of £700, so in reality its prob got around £300 worth of work needing doing to it, as alot of mot places like to try and over charge cos they know ppl think he must know what hes on bout as he is a mot tester
Offline clipperjay
« Reply #21 on: 03 April 2008, 16:30 »
To me.... you could buy a lump for £250-£300 and the rest spend the rest on labour and spare parts for £700 so thats quite involved job! So £700 for MOT failure even its the brakes, tyres, CV boots and suspension (common failure) it would not come up to that much. You need the report and read what it failed on then take time out to get someone to assess the amount of labour and parts needed. Then take it from there another £50 for the re-test if you have to, as it could save you £400!
Offline Tornado
« Reply #22 on: 03 April 2008, 19:17 »
Some of are you quite right.  I don't want a show car and it is going to be a daily runner - so that is the problem with DIY stuff. In my experience i start a little reapir , or so i think, and 3 days later it is still in bits and car cannot be used.  The bilk of the bill will be labour and VAT.  Needs Back brakes, Cv boot and joint, brake pipes (been bad for 3 years) also oil change, brake fluid change drain and refill coolant system and repair oil leak.  Oh and the MOT.
It is not that much but and none of it is a surprise to me. However labour and 17.5% to the taxman soon adds up.  As i have said though it is worth it. I hope to do more work on it myself so I can avoid these bills in future  :smiley:but i'll need to do it at the weekend when it is not being used!
Thanks for the advice. I promise to use spanners at every availible opportunuty.
PS the garage is local to me and is honest and there are one or two other things i have missed on the list of jobs; just little things but they add up.  Yes I could have taken the car away and done some of the work myself and obtained second hand parts but would taken me months so I gave the garage the go-ahead to save time. I am also fond of my comfort so I don't like spending hours in the cold and rain anymore ( I am 45 after all) and it doesn't get any easier!
« Last Edit: 03 April 2008, 19:24 by Tornado »
Lower!
Offline mattkh
« Reply #23 on: 03 April 2008, 20:21 »
Hi
Pay the taxman to get your car roadworthy. Where is the logic in VAT ?
If I were you, I would talk to the garage to negotiate a price for the work needed to get it MOT'd.
Once you got that, then whenever it is a nice day, you can yourself do the oil change. Do the coolant change another day. We will advise you.
Offline Tornado
« Reply #24 on: 03 April 2008, 20:42 »
Once it is up and running I will do more maintenance. i normally do oil and stuff but i am old and Lazy!!  :embarassed:
Lower!
Offline lowridermk2
« Reply #25 on: 03 April 2008, 23:05 »
at least you have an excuse....i'm young(ish) and lazy, thats even worse!! :grin: :grin:
Offline Tornado
« Reply #26 on: 04 April 2008, 01:20 »
Only marginally! :wink:
Lower!
Offline dabill
« Reply #27 on: 04 April 2008, 11:44 »
Quote
CV Boot and joint is a peice of pee, but a hub puller and track rod splitter from halfrauds, about 20 quid. then a new joint is about 20 quid too,
Undo hub nut while wheel is on and car is sat ont eh ground, use a scaffold pole and a 30mm socket. litrally, off with the wheel, two bolts for suspension leg, ball joint and track rod off. pull the hub using the tool, then get a hammer, give the cv joint a good smack from the rear and it just come off, then reversal. 2 hour job perhaps for a first timer.
oil change is a 10 min job, undo sump plug, drain oil. refit sump plug and refil oil.
coolant, 30 min job, undo bottom hose on rad, let all the water drain out. refil with 50% water, 50% anti-freeze. turn the heater on full, leave the expansion cap off, and run the motor, topping up when nessesary and squeezing pipes here and there, once the fan kicks in, on with the cap and your done.
oil leak will need more explanation.
brakes should cost no more than 40£ for an hours work bleeding them. changing rear calipers is easy too, second hand caliper from a car being broken is perhaps 20£ most, 30 min job to change so half hours labour at garage if you supply the brake calipers.
brake pipes will need doing though by a prof mechanic if you dont have the tools...
noble tuned - and still not fast enough!
Offline Dub90
« Reply #28 on: 04 April 2008, 12:55 »
Unless you are like me, after emptying the oil, I had a blonde moment and started the engine to move the car a bit.  :laugh:
Bora TDI 100
MK4 Golf 1.6 S
Offline dabill
« Reply #29 on: 04 April 2008, 13:27 »
 :grin: classic!
