Author Topic: Bigger profile tyres on 18 Monza's  (Read 2559 times)
Offline joesgti
Re: Bigger profile tyres on 18 Monza's
« Reply #10 on: 02 April 2008, 16:24 »
and you have a tdi!!! surley the tdi is alot more "comfortable" than a gti?!? i suggest you dont get coilovers  :grin:
GTI MK5
Not the only GTI...........but the best! ; )
Offline 182_blue
« Reply #11 on: 02 April 2008, 16:46 »
people are saying the fide with F1 eagles is more compliant ?, perhaps try them ?, what brand do u have now
NewGolf
« Reply #12 on: 02 April 2008, 16:52 »
If its comfort you are after, I would recommend changing the wheel size DOWN to 17". You could use standard VW 17" rims and put 225/45.17 tyres on. They are an option for the GTI. I test drove a GTI with 18" monzas on and found it a tiny bit bumpy on rough roads. With the 17's the rides a little bit more composed, the extra rubber gives a better ride. I researched the GTI before I bought it, and in quite a few of the revies, it mentioned that the 18" wheels were only there as an option for appearance and weren't recommended.
In fact I found one of the reviews I used, extract and link below.
"Backroad driving is a blast, with plenty of grip and traction thanks to beefy standard 17-inch tyres (18-inch wheels are optional, though not necessary). "
http://www.parkers.co.uk/cars/reviews/volkswagen/golf-gti-2005.aspx?page=2
I hope this helps a bit, I have the 17s and they look fine.   :nerd:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #13 on: 02 April 2008, 22:15 »
I don't think you're bonkers for changing to the 45's, however I would do if you only changed the 2 of them!!  You could perhaps sell your current tyres to offset the cost of the 4 new 45's??
The only things to watch, are:-
When you're speedo reads 60 mph, you'll actually be doing 62.1 & inform your ins. co. about the change, so you are covered.  (Your policy could be voided if they spotted tyres & you hadn't told them).
HTH  :afro:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
