Author Topic: perforated oil sump  (Read 906 times)
Offline JonM
perforated oil sump
« on: 01 April 2008, 14:59 »
Hi,
Investigating an on-going oil leak, apparently from nowhere, on my MkII Gti 8v, have noticed that the oil sump has a tiny crack in it towards the bottom at the front which is ensuring my garage floor is getting a nice coating of the black stuff.
Two questions
- is the sump likely to come off a 20odd year old car without turning the bolts off and ruining everything?
- Is there a "quick fix" - some sort of sealant or patch - that could delay the inevitable or at least give me a bit of time get the relevant spares together?
Many thanks for any help.
Jon
Offline ...joe
Re: perforated oil sump
« Reply #1 on: 01 April 2008, 15:05 »
1. yes it should come off easily. the bolts are usually coated with filth which will stop them being rusty etc, just make sure the socket is on there nicely.
2. no. you only need a sump and a gasket. sump is about £20 plus vat and gasket is about a tenner from www.gsfcarparts.com
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline JonM
« Reply #2 on: 01 April 2008, 16:17 »
Many thanks for the advice - I had a bit of a nightmare once trying to split the waterpump - most of the bolt heads just turned off.  Since then have been a bit wary.
Regards,
Jon
Offline tobz.
« Reply #3 on: 01 April 2008, 16:23 »
Might aswell whip your oil pump out while you're in there aswell (only two M6 bolts) and give the strainer on the pickup a good clean. This should help keep the old oil pressure buzzer problem at bay.
You got any pics of your dad's split ?
Offline H981CVV
« Reply #4 on: 01 April 2008, 18:37 »
i used chemical metal once to temp repair my sump until a new one arrived!! worked okay as long as its clean as a whistle first!
