Author Topic: Bleeding brakes mk2 8v gti  (Read 3603 times)
Offline UKjarvis
« on: 27 March 2008, 19:17 »
im going to try bleeding my brakes but have no idea how can anyone help.
Offline Diamond Hell
  • Opinions я Us
Re: Bleeding brakes mk2 8v gti
« Reply #1 on: 27 March 2008, 19:54 »
Yes, the search will help you.
Try searching for 'bleeding brakes'
Offline Conker
« Reply #2 on: 27 March 2008, 20:02 »
LOL.
Jarvis... When I get round to doing some work on my brakes I think I'll invest in an eazi-bleed kit to make a fiddly job a bit easier:
http://cgi.ebay.co.uk/NEW-GUNSONS-EEZI-BLEED-BRAKE-AND-CLUTCH-BLEEDER-KIT_W0QQitemZ180227247248QQihZ008QQcategoryZ30917QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Offline opel
« Reply #3 on: 27 March 2008, 20:31 »
it esier if u do it with 2 ppl. best way is person in car press pedal down while u undo bleed nipple. when they get to the floor lock biddle off and then letpedal go to top. then repeat basicaly. keep eye on brake fluid level keep it toped up.
Offline rowlers
  • I'm back - MK7 GTI
« Reply #4 on: 27 March 2008, 21:51 »
not the best way iirc, DON'T let the pedal go to the floor cos you can fook the master cylinder.
apparently best to use an easybleeder, although I did pump the pedal when I last bled mine, but was conscious of no going to the floor!
Offline boneybradley
  • Back in a Mk3...
« Reply #5 on: 27 March 2008, 22:19 »
and the rear calipers are a pain to bleed!!... easy bleed at least but you might need to swing the caliper up to make the bleed nipple level with the caliper as air gets trapped in the bottom otherwise (as the bleed screws are in a crap place...why would anybody fit bleed nipples midway on the caliper??)
Offline Simon8v91
« Reply #6 on: 28 March 2008, 11:11 »
Also, trapping open the rear brake bias valve helps alot when bleeding the rear calipers  :smiley:
