Author Topic: Remote Central Locking-Hard or Easy??...  (Read 6427 times)
Offline Ashley
Re: Remote Central Locking-Hard or Easy??...
« Reply #20 on: 06 April 2008, 11:18 »
a link to what buddy?
where bouts are you based? the remote + actual central locking only took me a couple of hours.. the wires should be quite easy with the instructions
Offline Benny T
« Reply #21 on: 07 April 2008, 18:10 »
Based in Gloucester mate, Bout you?
Would you be able to send me a pic of how you connected the boot one up. I don't know where to place it to screw it on, everywhere is only thin metal and will go through the otherside to the number plate :huh:, shal i put a block there?
Offline Ashley
« Reply #22 on: 08 April 2008, 00:59 »
if there isnt a frame to screw the holding plate to then put a block there yeah - dont go through your boot otherwise that'll pretty much screw up your bodywork..
i didnt do the boot, but drill a hole  in that plate then put the rod through and connect it in the normal way - the only problem is finding somewhere to put the long strip to support the solenoid
im based in cambridge - how far's that from where u r?
