Author Topic: building a car and ideal fist days and prices  (Read 14447 times)
Offline TRANTER
  • golf mkII gti 8v
« on: 26 March 2008, 19:44 »
hi all im new to this and its something i realy want to do, i have a golf mk2 gti 8v its stripped out from the front seats backwards, full exhaust system decent plugs, panel filter front and rear trut braces and so on and a new 12 months mot. if some could help me with a list of things i should do first would be a massive help like seats and harness what type? bushes anti roll bars? what needs doing basicly to help me  .brakes are  standard and arnt the best what can you recomend dont have alot of money but anything will hlp , brake lines and so on.
also where could i go for my first trackday just want a cheap day out to try my car as ive been told its the best way to sort your car out.
and another thing sorry do you have to have a roll cage fitted or can you take any car cheers all carl
Offline Diamond Hell
  • Opinions я Us
Re: building a car and ideal fist days and prices
« Reply #1 on: 27 March 2008, 00:24 »
You can take it without a cage - it's completely not necessary for track days.
However you should NOT fit harnesses without a cage - rear seatbelt points are not suitable to mount a harness to.  Instead fit a belt-lock to the standard inertia reel belts until you've got a FIA-approved 6 point cage fitted.  This should have harness mounting points in it.
Standard 239mm brakes are pretty lame.  The 16V 256mm set up is rather more robust and fade-resistant.  I have a set available for £60, if you want.  You'll need to upgrade the master cylinder to a 22mm item, too.
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #2 on: 27 March 2008, 02:02 »
first time out your best making sure youve no fluid leaks , everything it tight and in good condition
 you can have lots of fun in just a boggo road car thats what its al about
make sure tyre pressures are right , oil level (an keep an eye on it through the day) stuff like rubbers and arches arnt goin to leap off
 make sure your brake pads are fairly new and that your disks are in good condition - Maybe an upgrade in brake fluid and braided lines do make a difference
Offline TRANTER
  • golf mkII gti 8v
« Reply #3 on: 27 March 2008, 19:43 »
yes mate can you get more info on the brakes will they go straight on with no mods apart from the 22mm master cylinder whats the condition like but defo up for buying the brakes.
yea gona do my brakes and ive been looking into the full poly bush set just to help me out will leave the cage out for now but where can i get a belt locking kit cheers all carl
  • Opinions я Us
« Reply #4 on: 27 March 2008, 19:57 »
For CG-Lock go to this site.
The condition of the brakes is fine and yes, they bolt up to the bottom of your struts.  Get in contact if you want them.
Offline TRANTER
  • golf mkII gti 8v
« Reply #5 on: 27 March 2008, 20:51 »
sound mate can you get me a pic is it just calipers and so on but no pads and discs will all these need upgrading to discs n pads cheers mate
VeeDubGTI16v
« Reply #6 on: 28 March 2008, 19:49 »
i like the look of those cg locks! a bit dear though
Offline TRANTER
  • golf mkII gti 8v
« Reply #7 on: 29 March 2008, 14:10 »
yea £45is the best ive seen but its a hell of alot cheaper than a bucket n decent harness.
Offline lewis1641
  • stuck in the 90's
« Reply #8 on: 29 March 2008, 15:17 »
hi our first track car was completely standard bar being stripped out.  we then fitted some koni suspension and bought a second hand set of semi slick tyres.   they both made a massive difference to the driving, but bugger all difference to the amount o fun we had.  you need to decide if you are building the car mainly for fun or mainly for speed.
the one thing which yill ruin your day apart from mechanical failure is break fade.  we are still running standrd 8 valve brakes on the new car but with grooved disks (performance benefits probably negligable on a ar like this) standard pads(going for red stuff next time) dot 5.1 fluid and braided hoses.  we have not had any brake fade with the new car at all.  the standard brakes on the old car used to fade very quickly indeed.
new car has poly bushes which makes everything feel really tight.
if you have plenty of money to spend then go for the 16v brakes, good discs and pads, braided hoses and 5.1 fluid.  drop the suspension 40 mm , uprate the anti roll bars, poly bush everything,  upper and lower front strut braces, rear strut brace, roll cage, plastic windows, race tyres etc etc. or just uprate your brakes and spend the money on more track days!
as or first time out, airfield days are usually good as you tend to have more run off if things so wrong.
where are you located?
Offline TRANTER
  • golf mkII gti 8v
« Reply #9 on: 29 March 2008, 15:25 »
in telford shropshire mate but i would travel to things as its road legal to . i have front and rear strut braces full exhaust , lowerd around 40-50 mm standard brakes at the mo which i mite leave and do what you said add 5.1 fluid and decent pads and discs and ply bush everything and leave it like that for now.
is yours fitted with a cage?
its stripped out from the front seats backwards all front is still stand and i have four toyo proxy 1s on the front done 200 mile mate
what do you recomend mate i think ya car looks mint
