Author Topic: oem 2008 sat nav (MFD3), where to buy  (Read 48020 times)
Offline SteveP
Re: oem 2008 sat nav (MFD3), where to buy
« Reply #100 on: 10 September 2008, 20:15 »
Cheers Steve!!! lookin forward to it... will be burning some dvds full of music tonight!! Did you say I will need to install the speed camera's??
No problems, you have a PM about the speed camera stuff.  :smiley:
Offline Cass
« Reply #101 on: 10 September 2008, 20:20 »
Pics of the installation at various stages please - especially the wiring/connections (purely from a selfish point of view :smug:)
Cass
Now: VW Touareg Altitude V6 TDI 3.0 240 bhp, Diamond Pearlescent Black
Previous: MY2007 GTI, 3 door, manual, pearlescent black and lots of toys - gone to a good home : )
Offline R32UK
« Reply #102 on: 10 September 2008, 20:44 »
Cass
Sorry Cass Im not installing it myself... but will try get a few pics of whilst its going on.. just out of interest cass where are your gps signal thingys located?? I certainly dont want it visible.. but it looks like that may be the only option.
Offline 182_blue
« Reply #103 on: 10 September 2008, 20:46 »
Cass
cant you put it where i put mine ?
Offline Cass
« Reply #104 on: 10 September 2008, 20:59 »
My GPS antenna is the factory sharks fin aerial as I have the MFD2 fitted as a factory option. If you are not going down this route (you would need to route the cable under the roof lining and down the windscreen pillar to the rear of the unit), I would recommend you put your antenna under the centre grille as 182_blue suggests. The antenna will see enough satellites through the windscreen glass to operate the unit effectively.
Cass
Offline R32UK
« Reply #105 on: 11 September 2008, 08:59 »
Cheers Cass! By the centre grill i take it you mean the grill above the unit? Will putting it under the grill effect it ability to get a signal or is it able to work fine from under there??
Don think I willl go the whole hog and get the shark fin ariel as it will be coming out next year when the car goes back.
Offline 182_blue
« Reply #106 on: 11 September 2008, 09:10 »
as in the pic i posted (below), mine has always worked fine, never an issue here
Offline R32UK
« Reply #107 on: 11 September 2008, 09:36 »
Cheers Blue! Thats where is shall be going  :wink:
Havent been this excited since i got the car! So many more buttons to push :grin:
Any idea if there is a manual for the unit online somewhere??
Offline Bolle
« Reply #108 on: 11 September 2008, 09:53 »
I put my GPS receiver behind the instrument cluster, this was advised on various fora as being the best position. Has worked perfectly for me sofar!
Offline R32UK
« Reply #109 on: 11 September 2008, 09:56 »
Cheers Bolle! I think im i just going to stick it behind there somewhere it should be ok! As long as it warns me about speed cameras I dont mind taking the long way round :grin:
