Author Topic: Sorting out the Brakes..  (Read 1927 times)
Offline rowlers
  • I'm back - MK7 GTI
« on: 24 March 2008, 10:34 »
Up to press I have got a set of 2nd hand front calipers and a set of MK4 rear calipers. I have the conversion hoses and a 4 line kit of goodridges.
So far I'm planning on cleaning up the calipers and painting them with black hammerite.
What else can I do to ensure the calipers work to their full potential? DIY Caliper refurb How to anyone??
I'm also considering a new compensator valve - is this a worthwhile expense, I fairly certain (IIRC) it is seized, but is hasn't ever failed an MOT on this.
Was also think about new ahndbrake cables, but they haven;t snapped or owt so shold I leave til I NEED to changed, ditton for everything else?
Offline Jay
  • balding fat cvnt
Re: Sorting out the Brakes..
« Reply #1 on: 24 March 2008, 10:37 »
I'd change the hand brake cables if they are old, it's an easy job so worth it.
Offline rowlers
« Reply #2 on: 24 March 2008, 11:23 »
prob will as they are cheap enough :wink:
wot about the compensator valve, They are £40 ish, so not sure if worth doing :undecided:
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 24 March 2008, 11:31 »
Mine compensator need doing too. Its really stiff and was pointed out by the mot tester . Think I might get the brake lines done while im there as its all got to be bled any way. wonder if gscp do them. hmmm
Offline Jay
  • balding fat cvnt
« Reply #4 on: 24 March 2008, 11:35 »
If you are sure it's seized then it's better to do it than not and something go wrong because of it later.
Offline clipperjay
« Reply #5 on: 24 March 2008, 11:36 »
Good old wire brush and some white spirit remember to mask of any rubber boots on slider pins and such. Then go out by yourself some VHT(Very high temp) paint matt black looks nice. Laquire after wards if you want?
Then sort the lines out making sure you have clipped it properly to the strut away from moving parts.
New compensator valve worth doing when everything is out already.
Offline rowlers
« Reply #6 on: 24 March 2008, 11:41 »
cheers fellas...
What about the caliper sliders, seals pistons etc... is there anything to be done before I fit them?
Offline clipperjay
« Reply #7 on: 24 March 2008, 11:46 »
You might be able to get some sort of kit that replaces the boots and slider pins worth doing. Not sure if they can be overhalled find out if the dealers or ATE from euro carparts do a kit?
If I remember they come out with a bit of wriggling and you need to make sure there is loads of grease packed in so they don't seize again. If they move freely and no splits on the boots then leave them.
Offline rowlers
« Reply #8 on: 24 March 2008, 11:53 »
I'll have a good look before pulling them apart, they looked in decent nick tbh.
Offline golf8v
« Reply #9 on: 24 March 2008, 13:57 »
removed link mate hope you win it
« Last Edit: 24 March 2008, 17:26 by golf8v »
