Author Topic: 16v idle and starting to run out of options!!  (Read 2915 times)
Offline rowlers
  • I'm back - MK7 GTI
Re: 16v idle and starting to run out of options!!
« Reply #20 on: 24 March 2008, 22:10 »
you will not cure this idle prob without getting the CO and idle set up on a gas tester! The K-Jet just can't cope with random changes to it bits!!!
Offline H981CVV
« Reply #21 on: 24 March 2008, 22:15 »
i definatley will get the co set up, but it the guide on here as ive said before it reads " if it idles fine when hot or cold the co2 level is okay" and as mine idles perfectly when cold and hot and only has issues when warming up surely this means the co is correct. plus all ive change is the injector o rings so surely this wont alter the co2 drastically as the condtion of the old seals was almost perfect.
