Author Topic: conical air filter  (Read 2059 times)
Offline 2pac
conical air filter
« on: 23 March 2008, 07:59 »
hi
on my 1.6 driver i am going to build a wall around the airbox intake, to keep the air cold (i don't have the pipe attached to the wing).
after that, is it a good idea to fit a conical air filter to the intake?
Offline Khare
  • The bear that khares
Re: conical air filter
« Reply #1 on: 23 March 2008, 15:30 »
imo i think its better to leave it as it is. vw did it for a reason.
Offline golf8v
« Reply #2 on: 23 March 2008, 15:42 »
some carb models when air is to cold freezes the petrol could cause you more problems while cold weather is here
Offline Uruk Hai
« Reply #3 on: 23 March 2008, 17:43 »
Carb freezing can be a problem, I would just put a K&N element in it, that would be fine  :smiley:
Offline 2pac
« Reply #4 on: 23 March 2008, 19:06 »
you mean that the carb may freeze because i'll have to cancell the hot air intake from the exhaust manifold? well, i live in a warm zone, and my hot air intake is not connected for years, and i never had any problems.
so without the freezing risk, will a conical element give any benefit?
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 23 March 2008, 19:57 »
Quote
No.
« Reply #6 on: 25 March 2008, 17:25 »
and you cant fit one to the end of the driver airbox anyway, it will be before the warm air feed resulting in unfuiltered air being sucked into the engine from around the exhaust manifold.
Offline 2pac
« Reply #7 on: 25 March 2008, 22:51 »
but the warm air hose doesn't exist in my car, and the flap is always closed.
i get only cold air.
« Reply #8 on: 26 March 2008, 08:20 »
well fix that, otherwise the car will stall in cold/wet weather.  when the warm air flap is working properly it actually closes on full throttle, VW knew what they were doing ;)
Offline 2pac
« Reply #9 on: 26 March 2008, 08:29 »
it's been like that for years, never had problems. my manifold preheater also does'nt work :smiley:
on cold weather i just pull the choke as much as it takes (weber).
