Author Topic: what do ya recon...  (Read 2723 times)
Offline Lewy
Re: what do ya recon...
« Reply #10 on: 24 March 2008, 21:42 »
Yes and they're the hard plastic type, not the flimsy versions.
PM 'caddy vantastic' on here, and he'll give you an updated price and availability
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #11 on: 25 March 2008, 09:40 »
i got one 3 weeks ago at £25..amazing quality and re-designed to help stop etra water gettin in the foot wells :)
« Reply #12 on: 25 March 2008, 17:49 »
there are 2 halves to the covers:
192 819 415 C - main cover - 21.62+VAT
192 905 399 A - ecu cover - 5.77+VAT
Check your drain holes arn't blocked, and remove the ECU and check the connections on the plug for cossosion & damp.  The plug should be watertight, try smearing a bit of vaseline on the rubber seal before you plug it back in!
I'd also give it a full service, starting with the dizzy cap & rotor arm.  Dirt cheap from
http://www.vwspares.co.uk
Offline dTEA
  • back in an MK5
« Reply #13 on: 26 March 2008, 21:08 »
nice one cheers for that...i may even get my slag of mk2 ready to go back on the roads!
Edition 30 / T5 T32 Kombi
Offline wopdat
« Reply #14 on: 27 March 2008, 11:23 »
Your ECU should have a plastic cover over it followed by the scuttle tray. Spray WD40 on all the electrical/ignition components to displace the water and it should be fine.
Check the drain hole under the scuttle to make sure thay aren't clogged up so you don't get standing water around the ECU.
