Author Topic: Vacuum Hoses  (Read 1139 times)
Offline smithysmoo
Vacuum Hoses
« on: 21 March 2008, 17:02 »
Got an 8v PB engine golf.
the two vacuum hoses that come out of the front of the throttle body. The one is plugged!!! Also the one on the back of the body is also plugged is this correct??? Surely they must go somehere.
Offline cняis
Re: Vacuum Hoses
« Reply #1 on: 21 March 2008, 18:06 »
i think theyre meant to be plugged  :wink:
Offline smithysmoo
Re: Vacuum Hoses
« Reply #2 on: 21 March 2008, 18:32 »
cheers mate
Just trying to find the cause of a weird idle problem.
Offline cняis
Re: Vacuum Hoses
« Reply #3 on: 21 March 2008, 18:34 »
when does it idle funny? hot or cold?
Offline smithysmoo
Re: Vacuum Hoses
« Reply #4 on: 21 March 2008, 21:32 »
Mainly revs high when cold, but will also do it if turned off for a second and turned back on. So would still be hot. Hunts idles every now and again, and also will work fine every so often. Really is doing my head in....I've just done service with filter dizzy rotor plugs....I've checked for leaks and also cleaned out the ISV and all components..I'm off for a new bung for the flying saucer although mine don't look to bad. Also changed blue temp sender. Not sure where else to go.
Re: Vacuum Hoses
« Reply #5 on: 25 March 2008, 17:22 »
yep shoudl be plugged, on the front the one closest to the rubber boot is the one that should be plugged, i.e. driver side on a RHD MK2.  Check your idle switch!
