Author Topic: mk1 problems  (Read 2238 times)
Offline duck
mk1 problems
« on: 21 March 2008, 16:36 »
hi i av a mki golf gti 1.8 16v when i start it in the morning an whan i try to drive the thing ther is a dead spot when only cold an there is anuther problem when i stop at any time it revs up an down i av been told that that it could be the idle,speed valve.  as any one elts ad this problem or do any now what it could be thanks pip...
Offline [han]
  • Graphic Designer for Haribo
Re: mk1 problems
« Reply #1 on: 21 March 2008, 17:24 »
try using the search function, other people have had similiar problems, understanding theirs may help you understand yours.
Keep it specific to mk1, or possibly mk2 sections i guess if the engines are the same. :)
Dinky
Re: mk1 problems
« Reply #2 on: 21 March 2008, 17:54 »
dead spot? as in hesitation on your acclerator? digi - lag?
flux on your idle...could be a variety of things.. the idle it's self, dizzy, rotor - have you serviced it recently? timing, air flow, fuel flow...tons of stuff.. as Han has said, if yours is a mk2 digi 16v, maybs having a search within the mk2 section would be more helpful?
Dinx :kiss:
« Last Edit: 21 March 2008, 17:57 by Dinx »
Offline gibby
Re: mk1 problems
« Reply #3 on: 21 March 2008, 20:41 »
mk2 16v is k-jet not digi :wink: As mentioned, it really could be a number of things, maybe a dodgy earth connection.
......now officially dubless.
Dinky
Re: mk1 problems
« Reply #4 on: 21 March 2008, 21:12 »
its ok...im a gonk.. you wouldn't think I had a mk2 engine in my car :laugh:
plus i can't multi-task..  :embarassed:
Dinx :kiss:
« Last Edit: 21 March 2008, 21:21 by Dinx »
Offline raferackstraw
Re: mk1 problems
« Reply #5 on: 21 March 2008, 21:13 »
hi  do the search as said look for idling problems, hunting,etc
idle control valve on rhs of intake manifold is worth a clean as is checking/replacing vacuum hoses, do these before anything else [nb vacuum hoses may look ok but replace them it saves a lot of grief]
look for loose breather pipes and clean all engine earths and electrical connections
then check/replace spark plugs/ignition leads/rotorarm and cap
get co2 checked and ignition timing
i found it was pointless doing co2 & timing before checking the other items
i hope this helps  :smiley:
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline rustys_mk1
Re: mk1 problems
« Reply #6 on: 09 April 2008, 01:24 »
could be inlet manifold gasket as if this goes it leans off your mixture and send the revs funny.
