Author Topic: Help what is it????  (Read 1744 times)
Offline smithysmoo
Help what is it????
« on: 21 March 2008, 15:14 »
Its a thickish bosch wire bolted with 13mm bolt to the front of the head and then connects to a connecter. ITs to the left of the Temp switch and lower down. Its black covered, mine is split and theres a thick silver wire underneath.
any ideas please........
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
Re: Help what is it????
« Reply #1 on: 21 March 2008, 15:28 »
is it the knock sensor thingy, take it its an 8v
Offline smithysmoo
« Reply #2 on: 21 March 2008, 15:34 »
Yes is an 8v,
Whats this do then as the black covering is cracked and I can see the wire underneath....Wandering if its worth getting another one.
« Reply #3 on: 21 March 2008, 15:35 »
http://cgi.ebay.co.uk/KNOCK-SENSOR-740mm-New-Genuine-VW-CORRADO-G60-GOLF_W0QQitemZ220214949061QQihZ012QQcategoryZ9889QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
found this on ebay, can cause the engine to run rough if damaged. when fitting a new one make sure you torque it correctly as you can brake it or it won't work properly
« Reply #4 on: 21 March 2008, 15:36 »
make sure you get the right one this is for 86-89
Offline smithysmoo
« Reply #5 on: 21 March 2008, 15:46 »
Cheers mate I'll check the part num on mine is correct as mine isn't a green connection but is an 89 golf.
Just searched an its 20nm wander if this could be my rough idle problem...
they expensive to buy from the main stealer.
« Reply #6 on: 21 March 2008, 15:56 »
not sure probably not cheap. think they are main dealer only too
Offline Diamond Hell
  • Opinions я Us
« Reply #7 on: 21 March 2008, 16:00 »
From a recent thread on here it's about £50 from VW.  It manages the advance and retard on the ignition, so your engine runs properly.
Offline smithysmoo
« Reply #8 on: 21 March 2008, 16:07 »
Gees 50 smackers  :cry: Could be my idle problem then!!!
  • Opinions я Us
« Reply #9 on: 21 March 2008, 16:14 »
Well you could always go find one in a scrapyard - they're fitted to pretty much all of the injected motors in the VW range from that era.
That's surely pocket-fodder from a scrappy.
