Author Topic: vag com lead  (Read 1873 times)
Offline Mowzer
Re: vag com lead
« Reply #10 on: 21 March 2008, 16:10 »
Yeah just found that out  :smiley:
Offline MowatGTI
Re: vag com lead
« Reply #11 on: 21 March 2008, 16:22 »
This post has to be made a sticky.
For Novice's like myself, its great.
I thought Vagcom was really expensive.
I'm thinking on getting it.  It'll be cheap to buy, but it'll show all the faults which will cost $$$ to sort!
 :huh: :huh: :huh: :huh: :huh: :huh: :huh:
Offline Pete Taylor
Re: vag com lead
« Reply #12 on: 21 March 2008, 16:41 »
Not necessarily. You've already saved yourself an initial £50 diagnostic scan from a garage. Some things can be fixed yourself so you don't need to pay labour. If you're not scared of getting hold of a spanner, get yourself a haynes and people on here can talk you through how to fix anything
Offline MowatGTI
Re: vag com lead
« Reply #13 on: 28 April 2008, 14:38 »
Right - just bought it off the bay and plugged it into the pc/car but can't seem to get anything to work.
Going to have a dig around the little cd i got with it, but does anyone have an idiots plan on how to get it working?
Offline Pete Taylor
Re: vag com lead
« Reply #14 on: 30 April 2008, 13:47 »
What's the error message you get? There should be a file on the driver disc that explains how to set up the com ports if that's your problem, check the previous page on this post for a brief description on how to do it
Offline MowatGTI
Re: vag com lead
« Reply #15 on: 30 April 2008, 16:36 »
Cheers Pete.
Not going to be home for a couple of weeks so can't do anything untill then.
