Author Topic: 16v down pipe removal  (Read 1379 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 20 March 2008, 17:08 »
Can it be removed without having to drop the subframe and rack, ive got powersteering, Looks rather tight. I presume I will need to remove the gear linkages and twist it round??
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: 16v down pipe removal
« Reply #1 on: 20 March 2008, 18:48 »
yeh gear linkages will have to go, shouldnt have to drop the sub frame down, with the linkages outa the way it with a bit of wiggling it'll come out.
« Reply #2 on: 20 March 2008, 19:22 »
ive removed an 8v with no troubles. however this one seems v. tight
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
« Reply #3 on: 21 March 2008, 10:16 »
ye i had to change my 16v downpipe had power steerin to could not get it out and had it on the jcb forks in the air with me underneath lol
ended up cutting it in the middle where it bends pulled the rest out from the top.
« Reply #4 on: 21 March 2008, 13:06 »
Bloody hell!!!!!  it was tight. ive got a pit which was an advantage. had to bend it right round and also remove the gear linkage thingy. took about 30 minutes of carefull easing and out it came.
Offline hobbiniho
« Reply #5 on: 21 March 2008, 18:53 »
now to get the new one back in  :grin:
« Reply #6 on: 21 March 2008, 18:58 »
I've replaced it with a 4-1 which I just manged to weve in from the top had to take the rocker cover off to fit it. Again it was bloody tight. Also fittied a second hand miltec exhaust, needs a bit of adjustment as the back as its not sitting quite right but ive run out of energy.
Offline perryqhill
« Reply #7 on: 21 March 2008, 20:26 »
I've been doing mine today, without the benefit of a pit and Jesus - how tight?
Think I'll try taking the gear linkage off tomorrow (weather permitting  :undecided: ) and have another crack.
« Last Edit: 21 March 2008, 20:30 by perryqhill »
« Reply #8 on: 21 March 2008, 22:29 »
you will need some huge ramps i literaly had to twist it all the way around good luck!! you will need it.
