Author Topic: HELP im stuck. boost gauge  (Read 2164 times)
Offline duffy78
Re: HELP im stuck. boost gauge
« Reply #10 on: 19 March 2008, 10:17 »
good luck jo, lets us have a look once its in.
im going to have to ask the obvious though, what use would a boost gauge be?
wouldn;t you have been better off putitng something more useful in like something showing oil pressure?
Offline topher
  • Administrator
  • fully functioning
« Reply #11 on: 19 March 2008, 10:19 »
joes car is remapped so its worthwhile keeping an eye on the boost levels
Offline john_o
« Reply #12 on: 19 March 2008, 10:44 »
I will be doing APR soon , but even on a std car its worthwhile to check all is ok.
The OE dump valves are notoriously bad for failure , so its a sense check.
When the performance drops off , I can see if my boost levels change , if so I know where Ill be looking first  :smiley:
besides it looks cool  :cool:
downside is , its an indication you have modded even when you have not.
although the connectors on Defi mean its would be 2 minutes to remove gauge for warranty work if you wanted to
Black 3dr Edition 30 manual
DEFi boost gauge | ECS Dogbone | WLineAntiLiftKit
Offline joesgti
« Reply #13 on: 19 March 2008, 10:47 »
hey john quick question, i take it that i do not need the 3 way nipple that is provided as i have forge dv so i can put an extension in this?? :huh:
GTI MK5
Not the only GTI...........but the best! ; )
Offline john_o
« Reply #14 on: 19 March 2008, 12:32 »
forge DV should have a free connection you can take from.
If its already used for something you maye have to use the 3 way to splice into it
