Author Topic: K-jet or Ke-jet. Should I change?  (Read 8710 times)
Offline GIV
« on: 18 March 2008, 00:00 »
Now in the right place (sorry about that)... :embarassed:
I've just joined, and I have a question for you guys.
I own a mk2 Golf GTI 16v. It was an original PL engine with cat (Ke-Jet). The engine was swapped for a KR by the previous owner but that was the only thing he changed, so now Im running a KR engine with a Ke-Jet.
Already removed the cat (lambda still in), but I need some advice.
The car is running good, top speed bit low when comparing to what I hear from other GTI owners. Apart from that and a small idle issue, the car is running good.
Bottom question is, should I change back to k-jet? Will this bring any advantage?
Thanks for the help
Offline Diamond Hell
  • Opinions я Us
Re: K-jet or Ke-jet. Should I change?
« Reply #1 on: 18 March 2008, 16:27 »
Technically the KE-Jet should run better, with the electronic control on the lambda, but it's a hybrid electo-mechanical system, which is a massive compromise, unlike the K-Jet, which is a nice, simple mechanical system.  If I were you I'd bin the KE-Jet and fit an original KR K-Jet system.  KE has a reputation for being difficult.  You may need to check whether you need to swap out the fuel pump for a K-Jet one, too.
Offline Mew
« Reply #2 on: 19 March 2008, 04:38 »
That's probably because there is a lot of bullsh!t involved when some people talk about top speed  :wink:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #3 on: 19 March 2008, 09:12 »
^aye!
« Reply #4 on: 25 March 2008, 17:12 »
no need to change the fuel pump :)
Offline wopdat
« Reply #5 on: 27 March 2008, 12:02 »
K-jet is a better and simpler system. Ke-jet used to cause lots of problems in mk1's and early mk2's. if you can then change to k-jet. Also the top speed depends on the size of your airbox and inlet manifold. the earlier golfs had a smaller/skinnier airbox and a 42mm inlet instead of the 50mm in later models.
Do one thing at a time... you'll notice the difference each time.  :smug:
« Reply #6 on: 27 March 2008, 12:06 »
top speed relies more on the wheel size & gearing really!
Offline wopdat
« Reply #7 on: 27 March 2008, 12:15 »
That too... but airflow wise it makes a difference!  :smiley:
« Reply #8 on: 27 March 2008, 12:30 »
the inlet does yeah, but I doubt the airbox really makes a massive difference either way!
Offline Mew
« Reply #9 on: 27 March 2008, 12:35 »
Is it? I thought ke is what is used when there is a cat :huh:
