Author Topic: Old Wifes tale or not? Diesel oil as engine Flush!?  (Read 2518 times)
Offline Agreeable Slick
  • Unit
Re: Old Wifes tale or not? Diesel oil as engine Flush!?
« Reply #10 on: 20 March 2008, 21:50 »
biodiesel.
Works wonders. Get as stronger mix as you can though.
Offline ...joe
« Reply #11 on: 20 March 2008, 22:52 »
^^^ seriously what are the risks envolved here then? i've just changed the passat with synta silver but next time i'll definately want to try and clean it out...
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #12 on: 21 March 2008, 00:31 »
I'm not being funny, but there are products out there specifically designed to flush through engines! we use Forte products, on both petrol and diesel engines with exceptional results, Forte fuel additives are also very god as well, for the price of a round of drinks, why bother pissing around...
Tom
  • Unit
« Reply #13 on: 21 March 2008, 14:46 »
Right, as thom has suggested there are engine specific cleaners. For ease of use go for these imo.
Now, in regards to biodiesel it is a combustible heavy oil, more efficient than normal diesel, and less of a pollutant overall. It is also a detergent, i.e. will run through your system cleaning everything it goes past, however at the same time it will chow down on anything biological in the system, these include rubbers, nylons etc. So fuel piping, injector seals, piston rings are all susceptible to perishing. This is of course if you run it for ages.
So you can use it to flush the system in a neat form.  :nerd:
Offline Mr Blue
« Reply #14 on: 21 March 2008, 16:07 »
about diesel fuel
My dad topped my mk2 up with deisel
It ran much better and he swares by it
not sure about the engine oil flusher but ive heard transmission oil works well and is a good for running in new engines
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #15 on: 21 March 2008, 17:46 »
Use ATF Fluid as it is an oil so has good lubrication properties as well as strong cleaning agents.  You can drive the car on ATF.   Forte products will do the same things, they are very very good!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Alpinehead
« Reply #16 on: 22 March 2008, 23:52 »
let me get this right....  put this stuff in the engine... http://www.forteuk.co.uk/Top_end.htm  and it will shut my tappets up.
and then what?? replace oil and filter, or can i run the car on it?
soz to sound dumb but iv never had this problem b4 and never had to fix it!
