Author Topic: Removing Grill and Headlights  (Read 2594 times)
Offline Wizzkidd
  • Big fish, little fish, cardboard box \m/
« on: 16 March 2008, 16:07 »
Hi guys
just wondering if anyone can explain to me how to remove the grill in detail, as i get stuck when it comes to the bits under the headlights.
plus if anyone can tell me how to remove the headlights and rear lights that would be great!
cheers!
Offline boneybradley
  • Back in a Mk3...
Re: Removing Grill and Headlights
« Reply #1 on: 16 March 2008, 16:11 »
use this guide  http://www.diynexus.com/vw/mk3_front_end_swap/mk3_front_end_swap.html.. it's designed to help fit the vento front!
Offline Wizzkidd
« Reply #2 on: 16 March 2008, 16:14 »
still doesnt explain how to remove the bits under the lights :S
  • Back in a Mk3...
« Reply #3 on: 16 March 2008, 16:49 »
the grille is all 1 piece...removing the clips also removes the pieces under the lights
Offline Wizzkidd
« Reply #4 on: 16 March 2008, 16:53 »
i knw bt the pieces under the lights wont come off. and there isnt a gap to check for clips or anythin? :S
  • Back in a Mk3...
« Reply #5 on: 16 March 2008, 16:57 »
theres some small clips in that youll need a small screwdricer to undo... under the bottom of the grille located in the middle of the lights
Offline 95gtipete
« Reply #6 on: 17 March 2008, 20:47 »
boney is right as you pull the grill away slightly under each headlamp you poke a screwdriver in and unclip the grill.
Offline Wizzkidd
« Reply #7 on: 17 March 2008, 22:19 »
Ok done guys! cheers alot, see post just under this bou 1st mods,
that what you guys helped me accomplish! :D
