Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044951 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2760 on: 21 January 2013, 12:25 »
AFR wired in and all working
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline SoundillusioN
« Reply #2761 on: 21 January 2013, 13:13 »
Tidy.  :cool:
Offline tweed
« Reply #2762 on: 21 January 2013, 13:19 »
Looks great  :cool:
« Reply #2763 on: 21 January 2013, 13:25 »
Very neat and tidy :afro:
Offline BISSONE
« Reply #2764 on: 21 January 2013, 14:56 »
Didnt think your car had ABS?
Offline F17BAD
« Reply #2765 on: 21 January 2013, 15:16 »
cheers guys
it has no airbag either  :grin:
the original trim bit that was their had a great big daft LED for the original alarm in it, so i just replaced the trim with one from a car we broke that was a late car, hence the ABS/and airbag logo/lights
Offline dom
  • Back in a Mk4
« Reply #2766 on: 21 January 2013, 15:57 »
cheers guys
As with everything else on this build, looks almost factory fitted :afro:
Offline stow1985
  • 'when im cleaning winders'
« Reply #2767 on: 21 January 2013, 20:32 »
Thought Id catch up with some old projects can't believe this is still going...awesome!
Offline F17BAD
« Reply #2768 on: 21 January 2013, 20:41 »
Always tweeking and improving it mate
sleeping is cheating gotta keep it moving  :cool:
Offline F17BAD
« Reply #2769 on: 27 January 2013, 22:13 »
The sump is back and now on the car
its filled with Castrols most expensive oil (Edge FST 5W - 30 ) which is what Audi recommend for the high output engines, not cheap but needs must
sump is a piece of kit, loads of clearence - subframe is now lowest point :smiley:
shouts to ben for the aluminium boss which was made in double quick time to save the day - and still uses a original OEM Audi sump plug
(has to be mounted on the outside of the sump due to the pulley for oil pump been inside the sump in same area, and that goes right to the bottom of the sump so would foul if we was to weld anything on the inside
The boss is the same width as the OEM sump plug so the inside dimensions of the sump where the pulley sits are unchanged
here you can see the boss for oil drain
Here you can see new boss relocation for oil return. which also retains original angle of flow but now with larger hole for oil
And as you can see, we even still have the oil level sensor fitted
On the car (on axle stands - no engine under cover fitted here yet
Will get a picture tomorrow (or try to) of it with the car sat on the ground with engine undercover fitted
Feels good to be back behind the wheel of this car.. Brutal
