Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044951 times)
Offline DCmk3
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2710 on: 10 October 2012, 23:22 »
Ouch, poor tarmac!  :grin: How on earth did it even make contact?
Oh and that engine mount, isn't that the one you chopped a chunk out of?  :whistle:
2014 Mk7 GTI - Littco L500
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2711 on: 10 October 2012, 23:25 »
think their was something in the road as it was complete flat tarmac
and yea it was the very mount, made a error in cutting a square angular line out of it, needs to be a curve to take the stress
maybe it gave way meaning the engine hit the floor or the sump did  ? who knows, luckily the break wedged together so movement was only around 1CM
lucky ? probably
all good now tho, new braket has been subject to a correct strength and shock test
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline DCmk3
« Reply #2712 on: 10 October 2012, 23:29 »
Ah, that's possible that the mount basically jammed together and the engine just tapped the ground.
Just to think of it, if the engine had dropped completely to the floor it may have destroyed all of the mounts and other items..  :undecided:
Offline Bellend
« Reply #2713 on: 11 October 2012, 19:59 »
Only trouble is, what will give next time if it happens? :/
Where all my moneys went.
Offline F17BAD
« Reply #2714 on: 11 October 2012, 21:25 »
wont happen again, it really was down to the mount, and a weak point i had given it
school boy error :lipsrsealed:
just ordered newer coilpacks than the ones iv just fitted, should be here in a day or so
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #2715 on: 11 October 2012, 22:18 »
this is good brad lovin every update at the mo shame about the mount but like you say till something happens you can't really tell its a weak point! glad you have sorted it  :smiley: i have decided to go for a turbo on my abf and will keep you upto speed with progress  :smiley:
Offline Bellend
« Reply #2716 on: 11 October 2012, 23:05 »
Nah I mean if the car bottoms out again, what's the next point to go sorta thing?
Quality build though, wish I had the funds!
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2717 on: 12 October 2012, 10:04 »
You could say that about any car though as there will always be a weakest point regardless.
Offline F17BAD
« Reply #2718 on: 12 October 2012, 17:18 »
Cheers for replys folks
Car is immense
No print outs yet as its still awaiting mapping
Next on my list  :evil:
Offline F17BAD
« Reply #2719 on: 18 October 2012, 18:19 »
Updated the 2.0TFSI coilpacks to latest revision items
Also switched to a colder Spark plug which i should have really done a while ago, much better for high power / Bigger Turbo application
the legendary NGK 7's
