Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044993 times)
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2580 on: 21 July 2012, 23:43 »
Going to be awesome when finished :smiley:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2581 on: 22 July 2012, 00:04 »
cheers wayne :-)
JKM, where is that place ?  what date  ?
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #2582 on: 22 July 2012, 18:53 »
Portsmouth and it's whenever Khare organises it  :laugh:
Offline F17BAD
« Reply #2583 on: 22 July 2012, 20:29 »
that would one hell of a road trip, will have to give that some consideration
Update on car, got the new rods installed, was held up by trying to remove crank bolt to fix a weeping seal, managed to get the bolt off just need to pick the seal out whci is been a bar steward
got all surfaces cleaned up and ready to rebuild back up tomorrow
new turbo set up looks like it will be a easy fit, especially the downpipe which i was worried about
left is K04 set up, right is the MTM kit, gonna cut the MTM pipe where the Flange is on the Ko4 pipe and have the same flange fabricated and welded so it will just bolt right up to my exhaust as normal.. RESULT! :cool:
will save rest of pictures for when its finished
Offline Neo Badness
  • Feet are for pedals
« Reply #2584 on: 22 July 2012, 20:55 »
That'll be badass :cool:
Offline funkyfive
« Reply #2585 on: 22 July 2012, 21:44 »
Come on Brad more power!!
Offline dom
  • Back in a Mk4
« Reply #2586 on: 23 July 2012, 11:21 »
Flipping heck Brad! I've just caught up on the last couple of month's worth of updates, one word - mental!!
New turbo is going to be mental, you'll have to take me out for a spin sometime :wink:
I'm looking forward to seeing this at Leeds next month :cool:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2587 on: 23 July 2012, 12:35 »
Is it finished yet?  :rolleyes: :grin:
You say Carbon have your ECU at the mo? Will they be mapping it while out of the car or you drive to them and map it on the rollers?  :embarassed: :undecided:
VW BUSH
« Reply #2588 on: 23 July 2012, 12:47 »
Yeah through the rear wheels.....
Offline F17BAD
« Reply #2589 on: 23 July 2012, 19:22 »
ECU is getting sent to QST (MTM UK people) for the correct map putting on it..  (carbon have the MTM one that came with the kit  thats no good for my engine as it was from a APY which is a lot different to the AMK and BAM units
QST have asked me to send both the ECU;s and they will sort the correct map on to my ECU and post them back
car will then be drivable.... right to Carbon for custom map
had a test mount earlier, Wastegate fits with LOADS of space, Turbo fits with space, MTM downpipe has too much of a swing on the bend and is hitting my Rear engine mount!!! :angry:
Having to cut it up and re weld, failing that the car will have to go to my fabricators to have a whole new one made... Ben seems to think his idea will work so we will see tomorrow
