Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045305 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2520 on: 01 July 2012, 20:00 »
 :grin: like it
Also forgot to mention we Pollybushed the rear beam
gave it a refresh with paint too
Some pics of parts of the MTM kit
K24 7200 Hybrid
External waste gate and MTM Manifold
Going to refresh a few parts on the wastegate over the next few days :-)
« Last Edit: 01 July 2012, 20:05 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline golf-sib
  • Турботазик
« Reply #2521 on: 01 July 2012, 20:19 »
What you doing with external wastegate, venting it out or back into the system?
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline F17BAD
« Reply #2522 on: 01 July 2012, 20:23 »
Back into system as per MTM did i think..
not sure what is best ????
Offline F17BAD
« Reply #2523 on: 01 July 2012, 21:03 »
what do you mean ?  its direct bolt on kit for my engine :wink:
and believe it or not i actually have more room from the back of my engine to firewall than what the S3 does
the Charge pipe (that goes round the side of the engine) that came with the kit is a OEM item modified.. it gives more clearance and also removes the baffled part
the Downpipe is a 3" item.. I'm having a custom one done in same size but to suit my shell and no cat set up
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2524 on: 01 July 2012, 21:16 »
Boooosssst on its way   :grin:
 01455 617233
Offline F17BAD
« Reply #2525 on: 01 July 2012, 21:16 »
it mounts the way it is in the picture, you can just see the top of the waste gate once its fitted, it is a tight fit, but it does go..
ill take lots of pics when we are fitting it.  :smiley:
Offline Diamond Hell
  • Opinions я Us
« Reply #2526 on: 01 July 2012, 21:19 »
here is the Hotgolf Lightened and balanced flywheels next to the regular ABF one, he has machined this to suit Turbo car, which is a lot different to how he would do N/A types
Uh huh.
He took the weight off the flywheel in a different way to which he would for an NA engine?
You probably need to get some explanation on that, because grams and kilos are the same whether they're being driven by an NA motor, or a turbo motor.  :grin:
And the weight that's taken off is around the outside of the flywheel, last time I checked.
So you're out there wasting the competition on private strips yet can't make it to Inters and there's no photos or video of the car in motion?
Here's the solution.
http://www.rwyb.co.uk/dates.php
Look - there are dates all the way through til October.
Offline F17BAD
« Reply #2527 on: 01 July 2012, 21:26 »
Hotgolf asked me the power of the car and future plans of the power, i told him, he did the work to suit that.. Turbo car can spin it a lot faster than NA.. he said on a NA he would take as much weight off as possible
thats all i know.. if you wanna know more, ask him the reasons...
Also, would be a bit hard to get to inters when the car was in bits awaiting gearbox etc  :grin: :grin: :grin:
The car is not a track car or a show car.. it is a daily driver.
not sure what videos you would like to see.. if you was local id take you out in it... maybe then you would STFU
Offline tshirt2k
  • Been there...Done that...
« Reply #2528 on: 02 July 2012, 15:08 »
Watch out Scene Police about!! :shocked:
Could it be the First MTM kitted Mk3??
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
« Reply #2529 on: 02 July 2012, 16:01 »
It will be the first according to MTM :smiley:
As u know, Iv spoke to them today regarding my set up toask a few questions
All the S3's that were fitted with this set up were done in house and not many were done, it cost a staggering £6500 plus fitting :shocked:
My kit is even rarer as it has the very sought after. K24 7200 hybrid turbo
@wolverline, the techical director says the Clearance with this kit versus the standard K04 set up is about the same, so I should have no issues (I hope)
