Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045249 times)
Offline Neo Badness
  • Feet are for pedals
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2440 on: 05 April 2012, 00:25 »
That is proper spec. :cool:
 I have done similar research and came to the same conclusion re wavetrac. Have you looked into cryo treating the gears?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2441 on: 05 April 2012, 13:10 »
Nice bit of kit that.  :wink:
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2442 on: 05 April 2012, 13:20 »
you had a play with the relentless mani and that tip yet?
are you going to go for an AGU head?
also... Thought of putting in the 1.8 20v na cams in?
not going for the Relentless mani mate due to quality issue and the way it glows red hot
going to go for JBS item, still toying with idea of bigger turbo tho too mate.
wjats the deal with NA 20V cams ?  never heard of this mod  :smiley:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #2443 on: 05 April 2012, 13:42 »
thats interesting info mate, cheers :wink: :cool:
will make a decision on which way to go with engine mods after the LSD is fitted, thought it was best to prep the chassis as much as i can so I'm not loosing any performance...  stuff most people don't bother doing
Offline F17BAD
« Reply #2444 on: 05 April 2012, 13:49 »
i just meant in terse of the running gear, switching to MK4 driveshafts too as much thicker
Offline F17BAD
« Reply #2445 on: 05 April 2012, 14:10 »
yeah i already have the Drive shafts
also got round to refurbing a set of MK4 rear callipers
had the conversion (MK4 TO MK3) lines made up to match my fronts
Also refurbished a spare AUX belt tensioner too
Offline F17BAD
« Reply #2446 on: 05 April 2012, 14:25 »
Angle is fairly flat mate TBH.. never had a issue however the MK3 items that have lived on my car for 19 years have some rust marks now.. and theirs some kind of vibration dampener thing on the drivers side shaft, this had come away and i can feel a vibration
i kept the Mk4 ones from when i converted my dads car to AUQ with 6 speed box
his car has never ever been driven hard, and he bought it brand new.. the Mk4 box I'm using came from his car too   :smiley:
Offline jmsheahan
« Reply #2447 on: 05 April 2012, 14:28 »
Looks good. What did you use paint wise on the calipers?
Offline dragongreengolfgti
  • my golf gti mk3
« Reply #2448 on: 05 April 2012, 14:30 »
Good work mate loving this car even more  :smiley: Do mk4 driveshafts fit an ABF straight off or do you need there hubs and box also? reason i ask is i have a bit of vibration at the moment and i've replaced nearly everything i can on the front now but only thing i can think is i replaced my driveshafts with my old 8v ones possible this is the answer  :undecided: cheers
mike
Offline F17BAD
« Reply #2449 on: 05 April 2012, 14:36 »
Iv always used Hammerite paint on everything i do on engine parts and brakes.
the brakes are SMOOTH finish black as is the tensoner
i did the rocker cover in SATIN, and the Gearbox thats currently in is SATIN, new box will be the same too
here is tower and TT short shift iv refurbished
Satin black
Mike, not 100% sure but think the answer is a yes
