Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044951 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2400 on: 23 February 2012, 19:51 »
kells why don't you try the gearbox out first? its a lot of money to be spending to decide you want different ratios!
Those ratios won't work well on that engine. Would be good for a mk2/mk3 16v to make it more lively. But not for a high torque turbo motor.
yeah i may swell keep the 16v gearbox over the new one if this was the case
having the MK4 box on the bench is great, i can rebuild it and just swap out for my old box without having the car off the road
plus the Mk4 boxes are stronger
Cheers to russ for the help on this.. i was going to sell this mk4 box..which is a good one as it was in my dads mk4 from brand new when he bought it.. never had a hard life... will have soon hahsa.. joking  :evil:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline stow1985
  • 'when im cleaning winders'
« Reply #2401 on: 23 February 2012, 20:44 »
Good work again mate,
I saw a number plate the other day and instantly thought of you, 'S3 BAM'  :smug: it was on a ford tho  :rolleyes:
Not sure what size my breaks are, how do I find out? also how much do you want for the brakes?
Offline Seanl
« Reply #2402 on: 23 February 2012, 21:04 »
You've got a late mk3 stow, so yours are better than those at 288mm.
Offline F17BAD
« Reply #2403 on: 23 February 2012, 21:36 »
maybe Stow wants a piece of history with the old F17BAD anchors  :grin:
Yeah late cars are 288 so keep those? what year is the car ? ?
Offline stow1985
« Reply #2404 on: 24 February 2012, 20:49 »
 :grin: :grin:
M - Plate, 1995
Offline F17BAD
« Reply #2405 on: 24 February 2012, 20:51 »
:grin: :grin:
M - Plate, 1995
yours is GTI aint it ?
u could have either 280 or 288 if so
Offline stow1985
« Reply #2406 on: 24 February 2012, 20:52 »
Yeah GTI 8v, if that makes any difference  :undecided:
Offline F17BAD
« Reply #2407 on: 10 March 2012, 22:15 »
Today i fitted my Audi S3 brake set up.
312mm discs.
As updates previously iv refurbished these to a high standard :-)
the upgrade is needed due to the bad smoking I'm getting from the  280mm set up (early MK3 GTI set up) under hard braking.
I chose to got for a decent pad on these, after lots of consideration i chose EBC Yellowstuff. These get really good reviews. It is a track day pad but has very good bite from cold too
It is a Kevlar / Ceramic compound
Also had some braided lines made up from the Guys at HEL Performance.. got these at a superb deal with been a Club GTI member..  got Ben the Red ones for his MK3 too coz I'm a good mate like that
Mine are in the Carbon finish
(Big Thanks to Ben @ HEL for sorting these)
We Had to make up some spacers to fit the bigger carriers to my hubs
Here you can see the new spacers we made for the 312mm carriers, plus extended carrier bolts i sourced made from Super High Tensile steel. also added some washers.
280mm discs Versus the 312mm
All fitted:
was dark, but will get more pics in the daylight when the car is all back together (wing is off on this picture)
Still bedding in, first though was not good as i had bad juddering!!, seems this is the RED compound stuff thats on the pads from the factory to help them bed in..
By the time i arrived home these bad boys were already showing what stopping abilities they will have..
so far its impressive stuff, will report back later  :cool:
« Last Edit: 10 March 2012, 22:18 by F17BAD »
Offline stow1985
« Reply #2408 on: 10 March 2012, 22:32 »
Champion work!
Nice looking braided lines...are they better/more than the goodridge ones?
The Yellows pads look good behind the wheels, if your happy with, how about painting the callipers yellow too :cool:
Offline F17BAD
« Reply #2409 on: 10 March 2012, 22:37 »
i have Goodridge lines on my Swift, they are exactly the same if I'm honest.. came with new seals and bolts etc.. I'm impressed with them
I just want to keep the brakes Black as thats the theme of the car, iv also painted the centres of the discs and the outer rim Black too.. looks really good
