Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045222 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2200 on: 07 December 2011, 17:27 »
cheers for the replies etc
really happy with the pipe, iv took the polishing off the edges where the silicone 90 degree bends will seat, and i will be fitting this either tomorrow night or saturday morning
i need to use the car saturday nite as I have got important plans so it will deffo be fitted by then!
Sam, cheers mate.. yep times are worse than ever before. just trying to get by at the mo.. day at a time and all that...
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline F17BAD
« Reply #2201 on: 09 December 2011, 18:31 »
Got the new pipe fitted just now (hands are freezing)
works a charm and fits perfect, my silicone coupler needs some adjustment tho which ill either replace or carry out in the daylight another day
no pics as its dark.
Next stop for the car is going to be Carbon to get this Custom map sorted..just arraying this with the main man....
Also need them do logs on the MAF as i dunno if it is AGAIN on its way out.. that or one of the coil packs..  look g to replace the coil packs with the 2.0T versions and adapter plates tho from the USA :cool:
Offline F17BAD
« Reply #2202 on: 14 December 2011, 17:43 »
okay.. so the pipe i fitted the other day is spot on  :cool:
today saw the death to the Sump thats been for a week.... Yep a fooking week is all it lasted
my expensive oil is  now all over some floor in Leeds
Going to be taking Sump to my workshop where i had my pipe made up for some modifications to be made  :cool:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2203 on: 14 December 2011, 17:55 »
sump plate is 100% needed mate..
Offline SoundillusioN
« Reply #2204 on: 14 December 2011, 17:59 »
Time to raise the suspension!  :lipsrsealed:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2205 on: 14 December 2011, 18:03 »
such a defeatist !
Offline F17BAD
« Reply #2206 on: 14 December 2011, 18:04 »
Suspension raise is not a option
Modifications to sump is tho :-)
I have ideas  :wink: and if it works i will be offering to on all 20VT conversions we carry out
Offline Sam
  • Sam I am
« Reply #2207 on: 14 December 2011, 18:10 »
Shallow sump  :smiley:
Offline F17BAD
« Reply #2208 on: 14 December 2011, 18:16 »
rather stick pins in bens eyes than run one :grin:
no oil level sensor and running less than recommended oil is not what i personally would want to do on my car.. (just personal opinion)
« Reply #2209 on: 14 December 2011, 18:19 »
such a defeatist !
Not really, it was probably fine with the 8v lump in it but clearly not with this motor.  A guard may protect the sump but at the same time reduce your ground clearance even more.  It's still going to bottom out and I would not be happy about this with a car that has the kind of performance this one does now.
Edit:  I've lost track of this car a little, engine raise has been discussed before hasn't it?
