Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045217 times)
Offline tshirt2k
  • Been there...Done that...
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2160 on: 20 November 2011, 22:17 »
What happened with the hose?
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2161 on: 20 November 2011, 22:19 »
Don't know mate
i fitted a new N75 valve, and i think the car is now holding boost better, anyhow i popped the hose and upon refitting it i found this damage.. could have been like this a while ?
i am going to get this full piece made up in Aluminium tubing now i have the exact pattern of the route of piping, its the hot side that joins the intercooler to the charge pipe  :smiley:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tshirt2k
« Reply #2162 on: 20 November 2011, 22:30 »
Hmm.  That could be where the missing boost went. Wonder if this would have affected the mapping ? I had a similar issue withy map, when done with leaks.
Looks like something could have worn through it.  :undecided:
Offline F17BAD
« Reply #2163 on: 20 November 2011, 22:32 »
yeas it sits close to part of the front panel, could well be where issues have been.
just gonna replace the whole lot with metal.. no more issues like this then
Offline lemski
  • 16v
« Reply #2164 on: 20 November 2011, 22:50 »
i think thats why i would go all metal brad
Offline F17BAD
« Reply #2165 on: 21 November 2011, 13:37 »
Paint job scores 10 points no damage at all !! :-)
 Right can anybody put the grooved edges on aluminum pipe for me? It's for my replacement pipe work, I will get the pipe work and have it made up. Would just need the raised edges ? I know somebody on here had a machine to do it ?
Offline Sam
  • Sam I am
« Reply #2166 on: 21 November 2011, 18:08 »
Don't know mate
Changing to ally will aid heat dissipation slightly before the cooler too. May be worth looking into getting a little more airflow around the bay though because of this. Only minor differences but you are chasing ponies and every little helps
As stated, its called beading. There are machines/hand tools that do it by rolling the inside of the pipe for not alot of monies. Failing that a local fabrication shop will have tig/mig and should be able to run a run of weld around it for pennies. There is also a few ways of creating a DIY tool which are fairly simple but knowing your craving for 'perfection' this route may give too much of a backyard finish to the job.
here is diy
« Last Edit: 21 November 2011, 18:21 by caistor_bmx »
Offline F17BAD
« Reply #2167 on: 21 November 2011, 18:15 »
cheers dude, i do have opened up vents in this area however
but as you say, every pony
 counts :-)
@Wolverline - thats the one  :wink: sure somebody on here had a machine to do it ?
Offline F17BAD
« Reply #2168 on: 21 November 2011, 18:29 »
Caistor i do want a perfect finish for the bay, this car is now about the performance but also the fit and finish too...  without been just a show queen..
Wolverline think it was him yeah
Offline F17BAD
« Reply #2169 on: 22 November 2011, 17:50 »
Ok.. so 2 bad things happened today
1: i almost cut off my finger
2 the Sump is now no use.. finally given way due to hitting the ground some more
New one is on its way, and iv also found somebody to do my pipe work so ill get this done too :-)
