Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045249 times)
Offline golf-sib
  • Турботазик
Re: F17BAD G3 GTI. S3 TURBO
« Reply #1750 on: 04 August 2011, 12:32 »
whilst there take the VW badge off and put a seat one on, and since its part Leon, tear half off the golf badge off and add half of the Leon one on. then it will be a "Lelf" or a "Goon". It worked with the Bolf  :grin:
whilst on there, since its a s car the first letter needs to be an s, so it will be a "soon" or a "self". Not sure how to cooperate the Porsche into it, but wheels usually don't count...
« Last Edit: 04 August 2011, 12:38 by golf-sib »
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1751 on: 04 August 2011, 12:39 »
 :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline golf-sib
  • Турботазик
« Reply #1752 on: 04 August 2011, 12:43 »
Makes for pub talk when you explain to them you have vag soon or self... actually forget it! Try explaining that whilst drunk or to someone drunk.  :grin:
1.8T AGU..
R135
  24
Offline Seanl
« Reply #1753 on: 04 August 2011, 12:47 »
 :grin:
I didnt know the LCR had that lump either so it worked for me. I think the S3 badge on the clocks is a bit pointless, but again, I can appreciate the effort that has gone in, and to even do this just adds to that effort. Never met Brad, but always been good to me when talking on the forum. At the end of the day, its his car, and he can do WTF he likes to it. And I like it immensely too! Agree, also its the cleanest and best on the forum and a credit to the dedication and OCD that has gone into it.  :wink:
Offline Fabla
  • Not quite a Golf. But it'll do.
« Reply #1754 on: 04 August 2011, 14:52 »
Passer by: 'Hi mate, nice car. What is it?'
F17BAD: Oh hi, it's a VW TT Cupra rs3 GTI Boxter  :laugh:
On a more serious note: What is the actual bhp & torque??
Offline Adam
« Reply #1755 on: 04 August 2011, 14:55 »
What did I start :(
Down Hill From Here.
Offline golf-sib
  • Турботазик
« Reply #1756 on: 04 August 2011, 15:08 »
What did I start :(
A S-Lelf or S-Goon depending how you look at it  :grin: :grin: :grin:
1.8T AGU..
R135
  24
Offline F17BAD
« Reply #1757 on: 04 August 2011, 15:39 »
right it goes like this:
the early S3 came with engine codes APY 210bhp (not a fan of this unit because its not as strong and does not have the features of the later S3 engines and also does not map to as much - so i did not want one of these)
Later S3 and all the LCR came with the AMK or BAM  (early S3 came with crap APY lump)
These 2 are exactly the same (Bam / Amk) apart from the standard Map
Bam - 225bhp (actually 222bhp to be nerdy :nerd:)
AMK - 210bhp
Iv taken this from the Audi sport forum:
Originally Posted by Duktor
so the only difference is the stamp for the engine code then ?
mechanically and spec wise then yes they are the same... there are of course subtle differences which make no difference to the performance but are a result of Audi using up the parts bin for the change over to facelift S3's...
One example of this is the bevel box bracket... an AMK S3 (Dane's) that is in for rods has a cast alloy bracket supporting the bevel box to the engine block whereas mine (also an AMK) has a pressed steel one... there will also be revisions to parts that change slightly over the years such as later version coil packs and stuff... depends where you want to go with it all...
At the end of the day, AMK and BAM map up the same... there is no compelling reason to choose BAM over AMK and vice versa other than BAM are in newer S3's... if you can afford to buy a newer S3 you will get a BAM, go for a changeover facelift and you get an AMK...
Same internals, same head... the earlier AMK's had the drillings for the SAI blocked with steel ball bearings as heads were being used up but are still the same small port head the BAM have (and the APY for that matter).
The differences are minimal and largely academic
So yeah, both the AMK and BAM are the ones to look for and map to the exact same because the only difference betrween the 2 codes is the standard mapping. the BAM engine was released for the all new (at the time) TT and Audi wanted this to be more powerfull out of the box than the S3.
Once the TT had made its place in the market the S3 also got the Bam as did the LCR...
Early LCR has the AMK and so do some later ones so its difficult to pin point which has what
Mine is the AMK (a late AMK at that) out of a 2003 LCR
you get more bang for your buck with a remap from the AMK tho coz its mapped down from standard :evil:
Mine had a few mods so for
3" custom Stainless steel downpipe,
NO CAT
K&N Induction kit
N249 delete
Full Jetex
Forge 007 DV
80mm TIP
Front mount intercooler
and will soon have a full custom remap so ill be looking at around 270 BHP mark  :cool:
« Last Edit: 05 August 2011, 08:41 by F17BAD »
Offline CCGTI
  • Fueled Society
« Reply #1758 on: 04 August 2011, 17:37 »
you spoke to MJ for me yet mate
Offline F17BAD
« Reply #1759 on: 04 August 2011, 18:32 »
Called him earlier but no answer, I'll bell him after my tea. He will be at home then so will be able to answer. He is always really busy at work  :smiley:
