Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044951 times)
Re: F17BAD G3 GTI. S3 TURBO
« Reply #1700 on: 31 July 2011, 19:02 »
yea i never said it wasnt. :smiley:
you were wrong tho in regard to thinking the engine is the same as whats found in annies, octavias and normal Cupras
lots of differances, even the early S3 engines (APY CODE) have diferences from the later and better AMK / BAM :wink:
Im not to familiar with the details of these engines, what are the variances in power output etc?
It is a minefield tbh, Leon Cupra, Octavia RS and Golf Anni (plus a few non Anni) had 180bhp, Cupra R and early S3 had 210bhp, they then switched to the 225bhp lump, I think the Cupra R ended with the same in the end as well.
« Last Edit: 31 July 2011, 19:04 by Wayne »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #1701 on: 31 July 2011, 19:05 »
Oh blimey that much difference, now i understand why people would choose to be so particular on the donor vehicle then.
« Reply #1702 on: 31 July 2011, 19:09 »
Well in a roundabout way the 1.8t was 150/180/210 or 225bhp but so many codes etc and some are rated more than others.
Offline Jamin
  • Mk3 Golf Gti 16v
« Reply #1703 on: 31 July 2011, 19:14 »
This car is bonkers....I love it and think the S3 badge is a nice touch.
Don't hate the player......have the game  :grin:
Offline tshirt2k
  • Been there...Done that...
« Reply #1704 on: 31 July 2011, 19:25 »
Main differences are turbos and vvt. K03 and k03s in normal 1.8t's. These are normally 150/180hp and will remap to 190hp(k03) and 210/225(k03s). The TT/S3/LCR (210/225hp) 1.8t comes with a k04, along with different injectors,vvt and lower compression ratio, will remap to 260/270hp.
That's why these engines are in higher demand.
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1705 on: 31 July 2011, 19:38 »
 :smiley: cheers mate
Regarding engines, theirs so much differences between the engines found in the notmal 20vt cars and then the S3/Cupra R/ Certain TT's
You can easy spot the difference by which side the throttle body is on. On waynes 180bhp, and on all the normal 20vt engines it sites on the left hand side of the inlet manifold
On the high output engines (APY, AMK, BAM) it sits on the right, you also get the bigger K04 turbo on these plus loads of other bits although the APY is not as good as the AMK/BAM.
AMK / BAM have stuff like VVT,
The only difference between the AMK and the Bam engines is the Map on the ECU. Audi wanted the then new out TT to be up on power over the S3 so it was mapped down. later facelift S3 and Cupra R got the Bam too
AMK does have bigger gudgeon pins and is regarded to be the stronger and more sought after (i have this engine in mine :nerd:)
take a read here
http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/90968-amk-bam-engine.html
and also take a look at this
Here is a pic of a Audi TT with the 180bhp engine as found in the annie and Octavia VRS - notich the engine cover shape and also the throttle body on the left
And hereis my AMK S3 lump, look at engine cover and also throttle body to the right. also notice the charge pipes down the left side of the engine, different shape manifold etc
Very sought after engines hence the price they go for (for a good one)
« Last Edit: 31 July 2011, 19:42 by F17BAD »
Not no ordinary GTI....
www.mixcloud.com/kells/
« Reply #1706 on: 31 July 2011, 19:42 »
Very handy guide :afro:
Offline F17BAD
« Reply #1707 on: 31 July 2011, 19:47 »
it is yea, needs a few bits filling in still, but basically AMK / BAM are same , forge crank, vvt large injectors etc
Offline F17BAD
« Reply #1708 on: 02 August 2011, 09:43 »
Small video with some of the conversion pics all thrown in...
http://youtu.be/xWr-YsCTmVo
 :cool:
« Reply #1709 on: 02 August 2011, 20:45 »
Awesome work and an amazing classic track.  :smiley:
