Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1044951 times)
Offline CCGTI
  • Fueled Society
Re: F17BAD G3 GTI. S3 TURBO
« Reply #1510 on: 29 June 2011, 19:02 »
sound mate, shot gun front
Offline Len
« Reply #1511 on: 30 June 2011, 08:40 »
Vented wing for cold air feed?
www.sas.org.uk
www.the-ace.org.uk
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1512 on: 30 June 2011, 09:10 »
Its not needed Len, the tip of the filter is out of the wing and looking at the ground - not close enough to get wet but in open cold air, its perfection for a induction kit, i dont even need to use any cold air feed ducting
If you remove your wash bottle you will notice the big open space where you can see the ground -  looking down thru the bay - this area is not in the enclosed area that the engine undercover guards (if this makes sense :laugh:)
in a nutshell, behind those lower bumper vents but its higher up to guard from rain etc
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline SoundillusioN
« Reply #1513 on: 30 June 2011, 10:02 »
Just caught up... looks ace this... as said, almost looks like it's always been there.. top work fella's. :afro:
Offline cняis
« Reply #1514 on: 30 June 2011, 10:17 »
Like  :smiley:
Well done!
Offline Len
« Reply #1515 on: 30 June 2011, 11:43 »
Yes but there is nothing (from what I can see in the photo) to stop it, also drawing hot air straight from the radiator?
www.sas.org.uk
www.the-ace.org.uk
« Reply #1516 on: 30 June 2011, 11:50 »
doubt it will pulling in that much from the rad where it is but you could always  remove one of the lights from your hella's!  :wink:  :grin:
Offline F17BAD
« Reply #1517 on: 30 June 2011, 11:58 »
its not possible to draw air from the Rad in the location its at
the rad is enclosed in on the mk3's anyhow, and the air filter is sat outside behind your indicators area.
My engine is also enclosed in too because iv fitted my full engine undercover which i had before (fits the S3 engine with only a very tiny bit of modifications)
Have a gander len in the corner behind your wash bottle behind your lights when u get a mo, u will see a open hole leading outside, the indiction kit is taking all the fresh air this has to offer  :wink: :cool:
removing a lamp was one of my facve options but its really not needed
cheers for compliments guys too  :cool: :smiley:
jamrock
« Reply #1518 on: 30 June 2011, 12:28 »
looking sweet.
in re the sump, iirc Freno?? has one on this mk2 golf s3. he is on club gti as he was being f**ked with on here by.....  :angry:
might be worth loking into, and also once u add the sump guard u wont have to worry at all
Offline Len
« Reply #1519 on: 30 June 2011, 12:56 »
I have been looking dont worry Brad!
I am going to have worse problems with the throttle bodies!
I do have to disagree about the fans though! They may well be enclosed but the the fans pull the air out into the engine compartment. Unless you seperate the filter completely you will be drawing hot air!
I am also looking at bonnet vents. As we all know from basic science hot air rises, so some vents one either side at the rear of the bonnet should help.
I too have the undertray and think that makes things worse as the hot air from rad can only join the heated air around the exhaust manifold.
www.sas.org.uk
www.the-ace.org.uk
