Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045244 times)
Offline Bellend
Re: F17BAD G3 GTI. S3 TURBO
« Reply #1380 on: 19 June 2011, 19:08 »
True, true.  :grin:
Happy days! I think the sender is on my GTi, it did that on the way home, didn't think I was gonna make it then shot up to half a tank which was right! I'm gonna try a sender in it.
I know it's been mentioned but what did you use to sort your bay first time round? Mines as minging as yours was, want it looking fresh.  :cool:
Where all my moneys went.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1381 on: 19 June 2011, 20:01 »
to sort the bay and engine first time round i used same method i used on this engine
i used a load of cans of Gunk spray, and WD40.. loads of rags and kitchen roll
if you want to polish bits up i used wire brush then wet and dry, then autosol (polishing takes some right looking after
if you wanna spray bits then use high temp paint and hammerite
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline tshirt2k
  • Been there...Done that...
« Reply #1382 on: 19 June 2011, 21:31 »
What was up with the clocks then?
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
« Reply #1383 on: 19 June 2011, 21:36 »
look in electrical section of Club GTI russ, iv just put a post up, you may be able to help me.
iv got no speedo, i need to check the wires to the gearbox, but iv included the colours in the thread over on CGTI, also i think the sender is iffy for the fuel, its working but now and again it raises or drops ?  what do you think?
everything else is working, just no MPG readings etc on the maf and no speedo, plus my miles are not going up
« Reply #1384 on: 19 June 2011, 21:38 »
Have you earthed the sender on the tank out, if the gauge rises then it is your problem.
Offline F17BAD
« Reply #1385 on: 19 June 2011, 21:40 »
no mate, how do i do this ?
« Reply #1386 on: 19 June 2011, 21:42 »
Pull the plug off the sender and earth it against metal, if the wiring is correct the gauge should rocket up.
Offline F17BAD
« Reply #1387 on: 19 June 2011, 21:44 »
which bit do i earth (is it a 2 pin plug)  if so which pin or do i earth any ??
Offline Bellend
« Reply #1388 on: 19 June 2011, 21:51 »
Cheers mate. Might polish the alternator. Probably paint the rocker cover, not pink though, doesn't suit the shape of it.  :grin:
I'll grab some Gunk.
I could never ground out my gauge, I just saw three wires but I'm sure two were for the pump and one the sender, grounding any out didn't do anything. Although that could be on a seperate plug, I never bothered, I just stuck some fuel in and the gauge worked.  :laugh:
« Reply #1389 on: 19 June 2011, 21:53 »
Cannot remember now as it has been a while  :smiley:
