Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045250 times)
Re: KELLS, BLACK G3 GTI..
« Reply #1050 on: 27 May 2011, 00:03 »
Gauge looks ok, makes use of the vent etc.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #1051 on: 27 May 2011, 00:13 »
badger5 tips are very very highly rated mate.. i had a forge one on mine with no issues.. i think its down to preferance.. also imo do it once do it right.. the cheap silicone pipes have less strength and can delaminate where something like forge or badger5 will not.. im sure someone will pipe up with something to the contrary.. but hey lol
Offline LowlifeDubber
« Reply #1052 on: 27 May 2011, 06:14 »
Enjoying reading this mate.Keep up the good work! :cool:
Offline tshirt2k
  • Been there...Done that...
« Reply #1053 on: 27 May 2011, 07:06 »
A mate of mine had some problems with some forge bits that had split and even had a hole in the IC where it wasnt welded properly. They were causing him various problems until we found them during a leak test. Luckily it was still in the warranty period and they were changed. Usually I'd say you gets what you pay, but I've had no problems with the "cheap" silicone bends I have bought from eBay etc. So I'd be inclined to try them out.
Mk3 ABF 16VT Megasquirt V3
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #1054 on: 27 May 2011, 09:57 »
nick at r Tech was saying the standard intake pipe is very restrictive, so will a silicone one (of any brand) solve this ??
this is my main question ??
cheers for these replies
RE Vent, ben has make up a metal plate that replaces the vent so i may be using that, ill see  :evil:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline dubsport
  • TDI POWAR!
« Reply #1055 on: 27 May 2011, 10:00 »
What turbo are you using mate? Ko3 ko3s? If you are I wouldn't bother with a silicone tip, don't think our pea shooters create enough boost to make the tip distort shape and make it restrictive :D
Offline F17BAD
« Reply #1056 on: 27 May 2011, 10:35 »
Mate iv got a S3 engine which is going to be mapped soon as it's in my car, turbo is K04
Offline tshirt2k
« Reply #1057 on: 27 May 2011, 10:54 »
I suppose as long as you can get one with a 3" bore. It should be ok. The extra cost for the others may not be justified.
Offline Rhyso
« Reply #1058 on: 27 May 2011, 10:59 »
Yes it will - that's why these aftermarket products exist  :wink:
Offline dubsport
  • TDI POWAR!
« Reply #1059 on: 27 May 2011, 11:02 »
haha really should read previous post  :embarassed:
Definitely looming forward to seeing this at edition mate!
