Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045249 times)
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: KELLS, BLACK G3 GTI..
« Reply #1000 on: 24 May 2011, 18:09 »
Ooooow u'll be at docs would love to see what this pulls on the dyno
me too mate, was originally after a reliable 250 hp.. so owt above that is cool for now till i get a limited slip diff... then i wanna do alot more to this engine  :lipsrsealed: :cool:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline lemski
  • 16v
« Reply #1001 on: 24 May 2011, 18:10 »
More is better in my eyes
Offline F17BAD
« Reply #1002 on: 24 May 2011, 18:48 »
yeap haha  :cool:
and this bad boy should help me along the way  :tongue:
Offline golf-sib
  • Турботазик
« Reply #1003 on: 24 May 2011, 19:50 »
You can get shallow sumps with oil pick up, I remember I was thinking of getting one at a point as I thought I was scraping. All I was smacking was the cat shield  :grin:
All depends how low you are, if its a 40-50mm drop (I'm talking on a mk4, not sure how low the engine would sit in a mk3) then I can't see the point off a shallow sump unless you're silly low.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
Offline tshirt2k
  • Been there...Done that...
« Reply #1004 on: 24 May 2011, 19:58 »
Think the same. Your car doesn't look that low TBH. All depends if you want to make the car handle sh*t or not and not be able to make use of all that power. if it becomes a problem, you could always change it after.
Mk3 ABF 16VT Megasquirt V3
« Reply #1005 on: 24 May 2011, 21:14 »
what are peoples opinion on the shallow sump ?   i want one but i hear they have no provision for a oil level sensor ??
I think you will be fine with a standard sump, try it first and see how low it is.
Offline F17BAD
« Reply #1006 on: 24 May 2011, 21:46 »
cool will see then
tshirt2k, car is very low - 100mm low or their abouts
Offline cняis
« Reply #1007 on: 24 May 2011, 22:49 »
too low and its unusable at speed anyway, unless the road is dead flat and smooth (i.e. race track). No twisty A/B road action for you  :grin:
Higher ride height will generate negative scene points though, which is why i lowered mine a touch recently  :lipsrsealed:
Offline F17BAD
« Reply #1008 on: 24 May 2011, 23:09 »
she handles how i like it to tbh, but i hear what you say 100%
ill see how the sump sits once  the engine is in the car
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #1009 on: 24 May 2011, 23:15 »
Kells great to see progress mate.. coming along nicely.. i missed out on a BAM lump on the bay everything turbo ancillaries etc for £700  :angry: :angry:
What you could do if your worried about running shallow sump and running less oil etc.. why not just remove standard sump and get it plated up with some heavy duty stainless steel then atleast you know you wont crack the sump and will only take chunks out the plated area.. worth a thought  :smiley:
Dan
