Author Topic: Idle on Digi  (Read 1738 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Idle on Digi
« Reply #10 on: 14 March 2008, 19:09 »
I replaced the gromet the other day, no joy  :sad:  Just been looking through a folder of reciepts that came with my car. It looks like this problem has been going on since Nov 05 with a few invoices saying 'look into rough idle' and a few parts being replaced over the years but with no joy. I felt the ICV whilst ignition on and its buzzing so dont think its that, maybe air flow meter?
Offline Nate187
Re: Idle on Digi
« Reply #11 on: 14 March 2008, 19:57 »
My idle stays at around 900rpm all the time even when its started cold and my rev range is full of flat spots. Im guessing i need a new Blue temp sender?
Its not a Gti without the stripe
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Idle on Digi
« Reply #12 on: 14 March 2008, 20:29 »
Might aswell put a blue sensor on as part of maintainance mate, costs £14 from dealer. When you have installed the sensor unplug the blue connector and rev 3 times letting it rev to 3k then back to normal before next rev. Re-connect blue plug. Another thing with it sitting at 900 when cold, is your warm air feed from manifold to airbox plugged in or could be perished?
Offline Nate187
Re: Idle on Digi
« Reply #13 on: 15 March 2008, 21:29 »
Sorry to be a royal PITA but where is the blue temp sender looking at this pic?
And paul there's a warm air feed from the manifold to airbox?  :huh:
This is the most complicated engine ive ever owned, so many sensors and stuff  :laugh:
I should buy a haynes manual really
« Last Edit: 16 March 2008, 00:19 by Nate187 »
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Idle on Digi
« Reply #14 on: 16 March 2008, 07:35 »
Where your dipstick is, to the right of that (as in a couple of inches) is a large hose. On that hose you will find 2 plugs, one black and one blue. These plugs are beside each other. Take the blue plug off and there is the blue sensor  :smiley:
Offline golfryder
Re: Idle on Digi
« Reply #15 on: 16 March 2008, 15:46 »
does it have any problem pulling or accelerating? that is quite a good sign of airflow meter malfunctioning. see if you can plug it into a emissions tester an see what it comes up with.
Offline Godzilla
  • <<<VR6 MADNESS>>>
Re: Idle on Digi
« Reply #16 on: 16 March 2008, 19:49 »
Not any real troubles pulling away. She is a bit flat until 4000rpm, been told this is fairly common and known as 'Digi-lag' to which a good tune up should solve.
