Author Topic: Running in.. ED30  (Read 3918 times)
Offline kenny.s
Re: Running in.. ED30
« Reply #20 on: 12 March 2008, 19:34 »
Personally i think the most important things are:
Wait until it's fully up to temperature before giving it any sort of load or revs and by that i dont just mean when the water temp is in the middle, wait a bit longer to give the oil a chance to warm through.
Dont labour the car in a high gear up hill etc, better to use a lower gear and use the revs dont worry about setting an artificial rev limit this wont do anything to aid running in, if anything it may hinder it.
Try to use engine braking as this helps to draw a vacumn in the cylinders which encourages oil to be drawn off the bores along with any metal particals.
It wont do the engine any harm to give it the occasional blast through the gears, even if this results in brief use of full throttle, you need this to get the rings to bed in properly which is the most important part of a new engine. The bearings, journals and everything else for that matter are made to such accurate tolerances now you dont need to worry about bedding them in, 20 years ago maybe when you could have high spots etc due to pi$$ poor machining and quality control. I just drove mine normally from the day i picked it up, i didnt rag the ar$e off it but i didnt give a second thought to letting it rev to 5 or 6k
Basically just drive the thing, use what ever amount of throttle feels right for what your doing, use what ever revs you like, ok dont bounch it off the rev limiter but dont drive it like there's a block of wood under the throttle either.
Offline R32UK
« Reply #21 on: 12 March 2008, 19:49 »
The biggest worry for me was not realising the tyres and brakes needed running in... there was gonna be one seriously messy R32/ford escort in my first week of ownership!
Offline Manu_R32
« Reply #22 on: 12 March 2008, 20:06 »
Doesnt sound good!..Might need to make sure i remember that  :grin:...Although i would think every one who is into their motors would know that brakes need bedding in...and i did read in the tyre test of EVO that its always best to get the Fresh tyres...the ones that havent been sitting in the shop for too long....they are easier to run in  :smiley:
OSIR Front Splitter - OSIR Rear Diffuser - RNS 510 - JL Audio Cleansweep - JL Audio 400/4 Amplifier - JL Audio ZR650 - Recaro Bucket Seats - 3.2 V6 of Pure Power!
Offline RedRobin
« Reply #23 on: 12 March 2008, 20:27 »
Try to use engine braking as this helps to draw a vacumn in the cylinders which encourages oil to be drawn off the bores along with any metal particles.
....I've now done 45,000 miles and my natural style of driving is to always use the gears for engine braking (over 40 years driving). I guess the info you've posted also applies beyond the running in period?
Offline hotrod
« Reply #24 on: 13 March 2008, 13:47 »
Hi guys,
All sound advice. My gut instinct is to drive normally (once fully-warmed up), with varied revs and loads on the engine. Not laboured, not thrashed.
Good points about the tyres and brakes though!
I’m really loving my car, it really wants to get up and go... certainly not a car to be lazy in... starting to enjoy driving again!
Cheers buddies... Hotrod.
GTI Edition 30 (1783)   Candy white   KKK04 turbo
