Author Topic: Fuel pipe question  (Read 1025 times)
Offline perryqhill
Fuel pipe question
« on: 08 March 2008, 20:15 »
Another day, another problem [LOL]
I was just about to undo the bolts holding the fuel pipes to the fuel filter and as I tried to loosen one of them I saw the filter turn and the metal pipe at the back of the filter creak and sure enough it started to leak [:^(]
The pipe is the one in the centre of the picture.
I'd rather buy new than a second hand one (if possible) so will this be main dealer only?
Offline Jay
  • balding fat cvnt
Re: Fuel pipe question
« Reply #1 on: 08 March 2008, 21:59 »
Local scrappy and egay are your best bets for 2nd hand. Local VW's probably only have new ones.
Offline Karl Mills
« Reply #2 on: 09 March 2008, 10:43 »
I've just had the same problem. The thread is here http://www.golfgtiforum.co.uk/index.php?topic=78982.0 If you contact power.steering@virgin.net he might be willing to make one up for you as he is doing for me. VW no longer do this part as I've called my local one. Good luck
Offline perryqhill
« Reply #3 on: 09 March 2008, 11:49 »
Cheers, I'll give him a try  :smiley:
Offline perryqhill
« Reply #4 on: 09 March 2008, 12:26 »
Also - what's the best way to remove the metal pipe from the flexi hose?
Mine doesn't seem to have anything holding it on, it's just very tight and I don't want to damage it when removing it.
Offline Karl Mills
« Reply #5 on: 09 March 2008, 16:56 »
It's not held on with anything, it's just a nipple end that slides into the fuel pipe. No advice I can give you other than gently turning and pulling the pipe once detached from the fuel filter at the same time. Don't worry if you split the hose at the end as you'll have enough hose to play with to re-attach to your new pipe.
Offline filthy
« Reply #6 on: 09 March 2008, 17:28 »
Thanks Karl!  :wink:
Perry, drop me an email at this addy  :wink:
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline perryqhill
« Reply #7 on: 09 March 2008, 18:42 »
Already sent mate  :wink:
