Author Topic: LL's Mk3 1.8t Cab  (Read 921513 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT SLEEPER [Rims revealed!]
« Reply #830 on: 29 January 2010, 18:38 »
ok AGU lambda sensor come today so fitting that now.
going to check the other rear wheel bearing too!!! :D Im going to do the front two asap too, just for good measure.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #831 on: 29 January 2010, 19:40 »
almost done. checked the front bearings, just the offside needs doing. played with the suspension bolts to try and get the wheels to have the same camber. dont know what it is, but they are now as similar as i can get them. will get the whole car properly aligned soon.
got the old lambda out (just the 1.4 to plug the hole). access is extremely limited! try getting a 22mm spanner in the gap where the sensor is!! gotta to do it from under the car.
putting the AGU one on now, plug it in and get the wheels back on and see what difference it makes!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #832 on: 29 January 2010, 20:29 »
done! :)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #833 on: 03 February 2010, 09:13 »
mini update.
played with the clutch cable and the shift mech last night to try and improve it. couldnt really get 4th before and now i can pretty easy. it goes into reverse smoother and 1st and 2nd are a little easier to get. 5th is still good. 3rd is similar to before but is a little easier, still need to punch it in and hold it until engaged.
I got the mk4 shift mech i could use. also got a spare vr mech and also a spare g60 box with the in-box mech. so i got spare parts for it, but i reckon it justs need adjusting. i just want to be able to grab each gear with ease!
front wheel bearing really needs sorting, so going to grab a genuine bearing from vw and get a mate to do it. hopefully get that done early next week or maybe this weekend if im lucky.
Oh and getting rims this week too :) will see how bothered i am at the time, but i kinda want to spray them before i put them on. probs end up cleaning them up and throwing them on :D
Offline LazyLunatic
  • MK3 20VT Project
« Reply #834 on: 04 February 2010, 13:35 »
To Do List:
shift mech
front offside wheel bearing
oil pressure switch
fresh oil and coolant
coolant temp sensor
thermostat
cambelt
"Other less important things" to-do list:
boost gauge
afr gauge
leccy windows/mirrors with gti door cards
front end/fmic mounting
bonnet lifters
sort bonnet out so it closes
sort out roof gutters
respray?
Offline Diamond Hell
  • Opinions я Us
« Reply #835 on: 04 February 2010, 14:19 »
Let me help you with that:
To Do List:
afr gauge
oil pressure switch
coolant temp sensor
thermostat
cambelt
shift mech
boost gauge
bonnet lifters
respray?
I'd find both a dead engine or a bonnet in the windscreen quite annoying  :grin:
Offline Jay
  • balding fat cvnt
« Reply #836 on: 04 February 2010, 14:30 »
having both would be even more annoying  :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #837 on: 04 February 2010, 14:38 »
trust me i got it right!
wheel bearing is very important!!!!
the bonnet closes, you just need to give it some and so i have a dented bonnet.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #838 on: 04 February 2010, 23:57 »
oh and looked at the wheel bearing and it turns out the hub nut was slowly coming lose. i tightened it up as much as i could by hand, but will grab a scaf bar or get a garage to air gun it tight, dont want it coming loose again! :D
next - shift mech, oil pressure switch and coolant temp sensor.
« Reply #839 on: 05 February 2010, 09:01 »
I might be wrong but overtightening it will damage it as you could crush the bearing.
