Author Topic: LL's Mk3 1.8t Cab  (Read 921581 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: LazyLunatic's MK3 1.8T Conversion [Almost done!]
« Reply #590 on: 02 September 2009, 12:57 »
yeah LOL :D
quite a difference. will get some before, during after pics up when its totally done.
thanks a lot m8 :)
Offline Diamond Hell
  • Opinions я Us
« Reply #591 on: 02 September 2009, 21:22 »
Some part numbers for you......
Seat Toledo ABF clutch cable for cable-change 'box with cable clutch: 1L0721335G
Tensioning bracket to hold the end of the cable outer from B3 Passat: 357199356
Cable from early B3 Passat to provide mechanical speedo drive: 358957803G
Offline LazyLunatic
  • MK3 20VT Project
« Reply #592 on: 08 September 2009, 08:31 »
cheers DH, will check out that tensioning bracket!
bit of an update:
i turned it over last night and it sounded smooth. just need to FULLY charge the battery and grab a couple more bits to finish it. need a piece of 2.5" id pipe to join the exhaust to the downpipe, if i can find some. also need a bracket for the clutch cable and a little piece for the throttle cable. but all the boost piping is sorted, and everything else seems good.
also need a new nearside front caliper cause the bleed nipple broke (couldnt be helped), and need to look at the gear linkage, as the stick seems to not select gears well, dont think its the box, but i got a spare g60 box incase.
Offline funkyfive
« Reply #593 on: 11 September 2009, 08:34 »
bit of an update:
You got any youtube videos yet fella?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #594 on: 11 September 2009, 17:51 »
bit of an update:
havent been working on it since last post, will be sorting out the throttle and clutch cable, as i got the bracket now. check out the dash wiring and add oil, filter and offer up the front end, add coolant, fuel, plugs, etc.
i got a cambelt, thought it would be worth doing, but came up with that idea AFTER i put the engine in :D should be fun......
then will just need a special pipe to connect the zaust and downpipe, but thats sorted.
then go legite and get it on the road wooooohhhooooo!
  • Opinions я Us
« Reply #595 on: 12 September 2009, 08:44 »
You are SO Mr Forward Planning
I say November at the very earliest.
Offline JC
  • Back in the North.
« Reply #596 on: 12 September 2009, 10:38 »
what year Mr Hell  :grin:
« Reply #597 on: 12 September 2009, 17:33 »
Offline dubsport
  • TDI POWAR!
« Reply #598 on: 13 September 2009, 12:39 »
im acctually excited to see this finished  :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #599 on: 14 September 2009, 09:01 »
^ :D :D :D "what year" hahaha!!!!
hopefully this year lol! but it probs wont be done until november though, that would be a sensible estimate judging by how things have gone so far.
dubsport, im excited too!!!!! i thought by this point i'd just want to get it done, but no, im still excited haha!
