Author Topic: LL's Mk3 1.8t Cab  (Read 922074 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1760 on: 27 November 2010, 09:34 »
I was well pleased with breaking down. Hi-5's all round! Found out what the problem was, given it was the hard way, but nonetheless I found out!
I will be listening to Ben @ QPeng next time!!!
Offline stugolfmk3
Re: LL's MK3 20VT
« Reply #1761 on: 28 November 2010, 11:32 »
yes u will be i spent hours on that on friday night haha love it tho  :drool:
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1762 on: 28 November 2010, 11:41 »
:D Yeah cheers bud. I just couldn't stop you though, you love it!
Offline stugolfmk3
Re: LL's MK3 20VT
« Reply #1763 on: 28 November 2010, 11:49 »
not as much as u haha  put the fuel pump in later then u will have full boost again forgot wat its like on high boost lol  :smiley:
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1764 on: 28 November 2010, 17:25 »
Lol, wasn't the fuel pump, it was the NEW coil pack's!!! F**king EuroCarParts! OEM VW ftw from now on!!!!
Bolted in a new set of Bosch super 4's and it didn't work. Old coilpacks - thought its the last ditch effort before driving up to see QPeng. It worked lol.
Only problem is now, its cutting out when I hit full throttle. Then it doesn't start, just turn's over. Then if you bump start it after 5 mins, it starts  :undecided:
« Last Edit: 28 November 2010, 17:30 by LazyLunatic »
Offline dom
  • Back in a Mk4
Re: LL's MK3 20VT
« Reply #1765 on: 28 November 2010, 17:34 »
One problem followed by another  :rolleyes:
You gonna complain to ECP? Try and get some ££ back?
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1766 on: 28 November 2010, 17:41 »
Yep its G A Y
Going back there and demanding my money back!
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1767 on: 28 November 2010, 18:46 »
Mmm, another thing. Had it idling and it was fine then put it in reverse and it died. Doesn't start now, just turns over. Checked the wiring and the fuel pump wire that goes to the ECU and it reads 0V with the ignition on. The fuel pump primes when the ignition is on though...
Starting to sound like an ECU problem. Unless its the fuel pump relay?? :(
Offline archie837
Re: LL's MK3 20VT
« Reply #1768 on: 29 November 2010, 11:58 »
Some rolling shots from the weekend
PHAT
Project longterm Airbanger.
PD150 Anni daily
Offline dubsport
  • TDI POWAR!
Re: LL's MK3 20VT
« Reply #1769 on: 29 November 2010, 12:45 »
If you want any original vw coilpacks that WORK mate I have 8 :lol:
