Author Topic: LL's Mk3 1.8t Cab  (Read 921408 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1680 on: 14 November 2010, 19:16 »
Well I guess it would let less light through. Its black vinyl with loads of little holes (well one-way vision printed black). Not sure how much it would effect the light output in terms of brightness...
Offline dom
  • Back in a Mk4
Re: LL's MK3 20VT
« Reply #1681 on: 14 November 2010, 19:22 »
Hmmm, i'm after quite a dark tint so would this be better than the other film? i'm not overly fussed about brightness but i'd imagine the flyeye film will allow more light through  :undecided:
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1682 on: 14 November 2010, 19:39 »
Difficult to say, the flyeye is a different effect. If you want a darker film I can make it darker, its not a problem :)
I use 40% for the average tint, any darker and it seems to really affect light output with standard bulbs any lighter and you don't get a tinted look.
If you want it darker, it can be done :)
Offline dom
  • Back in a Mk4
Re: LL's MK3 20VT
« Reply #1683 on: 14 November 2010, 23:08 »
Hmmm, just had another look at the pic in the classifieds section, don't spose you've got any pics of it on normal gti lights have you?? Sorry to be a pain  :embarassed:
Re: LL's MK3 20VT
« Reply #1684 on: 14 November 2010, 23:21 »
The ARB is fitted with the droplinks above the subframe. I'm sure the drop links are meant to sit below the subframe? Hint is in the name I guess :D
Either way, I have to get the ARB and droplinks sat below the subframe so I get it aligned. Should feel like a different car!
Wrong droplinks go above the wishbone
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1685 on: 15 November 2010, 08:12 »
Ahh, I see Wayne, nice one. Well I'm going to try and fit it below and see how I get on. Its the only way it can be done.
Dom - no pics on normal lights bud :(
Re: LL's MK3 20VT
« Reply #1686 on: 15 November 2010, 09:19 »
Cannot see it fitting or working below, if they are below you stand the chance of damage.
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1687 on: 15 November 2010, 09:39 »
It looked like it would fit, so I'm going to try it. As it is now, its causing damage.
Looked at it in a pit, so the car was on the ground, not jacked up. It would work, just not sure how much it would affect the car, but we'll see. Its the only option I got, cause raising it is not an option :D
Also, just for anyone else with a low mk3, its something you can't see unless your under the car when its not jacked up. The steering arm sits on the ARB.
« Last Edit: 15 November 2010, 09:40 by LazyLunatic »
Re: LL's MK3 20VT
« Reply #1688 on: 15 November 2010, 09:41 »
I would check and see if you have another problem, mine was as low on the front end and I had loads of clearance.
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT
« Reply #1689 on: 15 November 2010, 10:13 »
The GTi and non GTi models had different ARB's though didn't they?
I didn't have a problem before, but now I have gone that little bit lower the ARB and steering arm touch.
