Author Topic: LL's Mk3 1.8t Cab  (Read 921591 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: LL's MK3 20VT [Back OFF the road again FFF]
« Reply #1640 on: 03 November 2010, 12:33 »
New plugs and temp sensor and a new sidelight!
Going to cut the subframe open tonight, cut off the captive nut, weld in a new nut and weld back on the piece of subframe we took off.
The fit all the stuff I mentioned above, so plugs and packs, new rear pads and bolts, handbrake cables, two bottles of G12 coolant and some water, temp sensor, new coolant pipe, new rear sidelight, flyeye my headlights, and probs some more!
Offline lewis1641
  • stuck in the 90's
« Reply #1641 on: 03 November 2010, 12:48 »
sounds like a busy night. hope all goes well
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1642 on: 03 November 2010, 12:54 »
Yer it will be! Thanks mate, should be aite :)
« Reply #1643 on: 03 November 2010, 13:10 »
Not sure on this option, I guess you have no other choice but you run the risk of weakening the subframe.
Offline SoundillusioN
« Reply #1644 on: 03 November 2010, 13:21 »
yeah, does sound a little scary
Offline JC
  • Back in the North.
« Reply #1645 on: 03 November 2010, 13:27 »
as long as its a proper job it should be fine. but as its a mk3, it could be a whole world of rust pain  :lipsrsealed:
good luck
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1646 on: 03 November 2010, 14:59 »
Lol, no risk, just a small hole and when its welded back it will be good as new! Rather that than swap the subframe!!!
Chassis is pretty solid tbh and subframe was in good condition and when I did the conversion I striped it back and painted it.
Tyres should arrive this week, so saturday its down to get them fitted then it aligned, camber and tracking setup.
Offline robz
« Reply #1647 on: 03 November 2010, 15:02 »
have ya got a pic for the calendar mate??
cant not have yours in there!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1648 on: 03 November 2010, 15:50 »
Not yet, found a cool location, just need the car back on the road :D oh and get the phone camera working :D
Offline robz
« Reply #1649 on: 03 November 2010, 16:30 »
only got 4 more days buddy! :D
you and shady are worse than me for pushing the deadline :D
