Author Topic: LL's Mk3 1.8t Cab  (Read 922755 times)
Offline JC
  • Back in the North.
Re: LL's MK3 20VT Daily Hack [Bodywork in progress...]
« Reply #1150 on: 09 May 2010, 17:39 »
ooops, lets hope its an easy fix :afro:
« Reply #1151 on: 09 May 2010, 20:12 »
I take it your sill not running a knock sensor.
never was, never will be.
I was only asking as if you have say damaged a piston then a knock sensor could have helped.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1152 on: 10 May 2010, 21:58 »
after looking it today, it appears to be boost problems or maybe a weak spark. thinking maybe the n75 or maybe the diverter valve.
its all mechanically sound (within reason lol), its fueling good, etc. It runs fine off boost, but when it starts to come on boost, it starts to run like a bag of sh!t. i dont think there is a leak, as we checked it all over, but didnt pressure test it.
when it hits full boost, it makes a popping sound (fuel cut??) then has a loss of power and runs really sh!t.
it idles fine and apart from the above issues, its ok.
anyone shine some light on this?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1153 on: 12 May 2010, 08:20 »
after much thought and help by others, its now been diagnosed as the coilpacks. I guess its just one, but it would explain the very very very slight misfire/stutter that happened sometimes when the engine was cold and it came on boost. i guess that was the coilpack on it way out???
So i will send a nice set of ecs tuning hitachi "e" coil packs to the states and pick them up when i go over there in july. for now i will just replace the one thats broke and hope the others last until july!
Offline Dan34
  • VTEC Powerzzzz
« Reply #1154 on: 12 May 2010, 11:44 »
Coilpack failure is common as fook on 1.8T's, easy fix!  :smiley:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1155 on: 12 May 2010, 12:01 »
yer, dont know why i didnt think of it! i read up on it sooooo many times :D :D :D
"oh no oh no!!! headgasket! bottom end has gone!!! ooooooooo!!!" t**t.
:D :D :D :D :D
Offline Diamond Hell
  • Opinions я Us
« Reply #1156 on: 12 May 2010, 12:40 »
Have you actually done any diagnosis on this, or just arrived at a decision based on chin stroking and barstool philosophy?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1157 on: 12 May 2010, 12:54 »
yes i have.
Offline Paul86S2
« Reply #1158 on: 12 May 2010, 14:48 »
This seems to be a common weak spot on tuned turbo engines.
I seem to remember reading a fair few incidents of coil packs failing after ecu tuning in the tuning section.
Lets hope its that simple
Paul
Offline LazyLunatic
  • MK3 20VT Project
« Reply #1159 on: 13 May 2010, 15:14 »
twas a dead coilpack, number 2.
so fitted with a genuine vw coilpack (r spec) which i was given for free! thanks Dez!
so its all fixed and running sweet.
defo going to get on it and grab a new set of hitachi "e" coilpacks though. they should keep me going for a couple years or so.
now i just need to get my a$$ in gear and get it sprayed!
