Author Topic: car keys- where to get replacements?  (Read 1513 times)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
« on: 27 February 2008, 15:43 »
terrible's dilemma has got me worrying a bit, as I only have one key too.
Its just a normal plastic black key fob with the button missing.
(but i think it has an immobilizer chip inside)
From a 1996 gti 16v..
Is the dealer the only place to get a spare?
If so? how much?
Offline LazyLunatic
  • MK3 20VT Project
Re: car keys- where to get replacements?
« Reply #1 on: 27 February 2008, 15:47 »
Not sure, but I think if you just want to replace the key, not worry about programming key to alarm etc, then get a matching key from ebay (make sure it is same as original) and go to locksmith to get the key cut.  It is a cheap way to do it but if you want to get the immobilizer programmed in the key to the car, then that is more complex.
LL ;)
Offline saul79
« Reply #2 on: 27 February 2008, 22:36 »
key needs to be coded to ur car so buy a key with a chip in it
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 27 February 2008, 22:37 »
try a good key cutters that can code to your original...I paid £25 for the key and coding
Offline kr1s77
« Reply #4 on: 27 February 2008, 23:15 »
i paid £15 at my local key cutters, programmed and all
ASV 1.9 TDI 110
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
« Reply #5 on: 28 February 2008, 00:21 »
But what if you have an aftermarket immobaliser, surely you don't need the key coded then..? coz i need another key aswell as i only have one.
Offline Mikester
  • Civic Type R
« Reply #6 on: 28 February 2008, 00:24 »
I think the coded vw keys is a myth to be honest.
Offline saul79
« Reply #7 on: 28 February 2008, 19:14 »
mk3 golfs have coded keys from a certain buildyear
  • Back in a Mk3...
« Reply #8 on: 28 February 2008, 19:19 »
from 1995 model year they had a factory immobiliser thing built to the ecu/ignition switch and key and unless its being removed when an alarm has being fitted (or had the o.e key glued to the ignition colum) you will need a coded key.. I still need the correct key with my toad system!
Offline noms
« Reply #9 on: 29 February 2008, 09:08 »
I had the same problem when the only key I had got bent out of shape. I got a blank from the dealer, got it cut locally and then back to the dealer to code it. Cost me 70 quid in all, and that was still cheaper than dealer!
Watches, Women and VW's... The 3 best things in life.
