Author Topic: pigeon dump vavles???  (Read 4586 times)
Offline linz
  • vee-dub
Re: pigeon dump vavles???
« Reply #10 on: 26 February 2008, 13:14 »
lol toph u having a stressful day
i found this while searching the net it goes into detail about it though i got confused now im in two minds and not sure what to believe
http://www.imoc.co.uk/forums/viewtopic.php?t=88469&sid=4796ebb0149c8634b7092e72b11901e5
Offline Ashmond
  • Money, b!tches And Boost
« Reply #11 on: 26 February 2008, 14:00 »
Runs sweet as a nut like that, mine has been for a month and my mates 1.8t has been like that for2 years  :wink:
Offline linz
  • vee-dub
« Reply #12 on: 26 February 2008, 14:31 »
right so if i put on a norm dump valve its easy to change to and from??
also can you block it off n get the sound if the engine is completely standard?
Offline Ashmond
« Reply #13 on: 26 February 2008, 14:45 »
on a completely standard engine you wont hear it really, need a filter at least.
I had a baileys dv and just swapped them over every now and then to hear the flutter or the dump depending on my mood!
Offline linz
  • vee-dub
« Reply #14 on: 26 February 2008, 15:41 »
yh thats what il do i expect
what you think of the forge recirculation ones that also give you the tsssh sound
Offline Ashmond
« Reply #15 on: 26 February 2008, 16:18 »
the forge 007 (the one i used to show which pipes to block) will give you the same sound as you'l get from doing this (wastegate chatter) they are designed not to make any noise but if you have a filter it will make one.
The forge Split-R valve (what I got) comes with a trumpet or blankin plate, when you screw the trumpet in it gives a tsshhh sound, very similar to that on the rice mobiles and if you put the blanking plate in you get the pigeon flutter, hope this helps  :wink:
Offline linz
  • vee-dub
« Reply #16 on: 26 February 2008, 18:34 »
right ash plz do me a huge favour and go on ebay and show me which one i need to get please
i would like one i can have both sounds with i want the hatter mainly but be able to get tsssh if i want - jus by a very simple change
Offline Ashmond
« Reply #18 on: 27 February 2008, 09:11 »
Thats the one! All forge products come with a lifetime warranty too if the seals/springs go on it (like mine) then you send it back and they sort it out for free! Good bit of kit
Offline linz
  • vee-dub
« Reply #19 on: 27 February 2008, 11:39 »
nice one how easy is it to change over?
