Author Topic: Elec Windows not workin mk2 golf  (Read 628 times)
Offline veedubmk2golf
« on: 24 February 2008, 10:17 »
just wondering if anyone can tell me if I can use any other relay than 24 which it currently has, my windows no longer work and i'm guessing it cant be the switches and ive checked all fuses and they are fine so I think it could be the relay is goosed?
Can't find no loose wires and I removed the positive and negative and placed them on the battery to narrow whats wrong and they still don't work
thanks in advance
Offline Ben Lessani
Re: Elec Windows not workin mk2 golf
« Reply #1 on: 24 February 2008, 15:44 »
http://www.golfgtiforum.co.uk/index.php?topic=77889.0
Surely 1 post is sufficient - I doubt anyone will reply immediately! Pop the relay out, look at the underside, usually it identifies the circuit of the relay, with an ordinary automotive relay being
If its the same 4 pin layout, any ordinary relay would suffice - otherwise, just go to a breakers/dealers and grab an identical replacement.
