Author Topic: J 92 MK2 Golf GTI 16V engine cutting out below 1000 rpm  (Read 6454 times)
Offline Thom89
  • Looking for an "Icebreaker"
Re: J 92 MK2 Golf GTI 16V engine cutting out below 1000 rpm
« Reply #10 on: 23 January 2013, 19:17 »
Start with the basics, proper fuel from Shell/BP/ etc, no supermarket rubbish, and the correct triple pronged spark plugs, and a cleaned out Idle control valve...
Thom
Offline bodga
  • F reg GTI 16v
« Reply #11 on: 23 January 2013, 22:01 »
I've got this fault and i think its one of the ISV temp sensors on the side of the head on mine because the connector has corroded and broken off.  :laugh:
I have never put 97 RON in mine just supermarket stuff and it runs well. Have the proper three prong plugs fitted too. pulls very well after 4.5k revs like they supposed to. but yes it does say 97 RON on the filler cap, but that sticker is now 25 years old. I'm presuming fuel got better since then? but i have read some were 10% ethenol is in petrol now :undecided:, i'm no chemist but if it aint broke :rolleyes:
Offline Gambit
« Reply #12 on: 25 January 2013, 15:35 »
better fuel just means you can run more static advance on the dizzy which inturn gives you more go. it'll happily run on supermarket or normal unleaded with the dizzy retarded slightly
Offline bodga
  • F reg GTI 16v
« Reply #13 on: 28 January 2013, 21:33 »
so you saying someone has adjusted this to run on standard unleaded? and if i fill up with 97RON i will have to adjust the dizzy?
Also it will be alot quicker as a result?
Think i need to rolling road it to see how many horses i have at the mo then fill up with the premium unleaded and retest :nerd:
Anyone already tried this?
Offline clipperjay
« Reply #14 on: 04 February 2013, 09:00 »
Alot of the 16vers owners run premium due to the knocking of the piston which is when fuel is burnt either a cleanly or roughly one the big bangs can cause a knocking in the chamber which is why a knock sensor is on the 8vers to retard timing when its got stock fuel. On a 16ver you have no luxury of a knock sensor its usually all go which is why the head is more suited toward 99 Ron. Some people run advance timing all the time and sticking 99ron gives better performance, but if you stick 95 it runs badly.
You can retard the timing to run 95, but all that does is save the head from premature wear. TBF a 16ver is always going to drink fuel, but its a fools gold to think 95 is cheaper and you will get less efficiency from the block which uses more fuel in the long run. Most people will only run 95 for short periods if you can't get 99 stuff in an emergency but over time you can hear the engine knocking under load due to inferior octane levels. Either advance the dizzy or not but choose one or the other for better fuel consumptions and saving engine wear!
Offline CriticalPoint
  • 1.8GTI Wolfberg Edition
« Reply #15 on: 07 February 2013, 16:14 »
A cleaned out Idle control valve...
Thom, do you (as a mod!  :nerd:) have a link to a guide for this - My idle is high, and I wouldn't mind knowing what to clean it with etc - Thanks!
/Crit
