Author Topic: MOT explanation  (Read 1153 times)
Offline Davo13
MOT explanation
« on: 23 February 2008, 13:25 »
My car was MOT'd and one of the "Advisory Items" was - Front Brake Discs Showing Run out on brake tester.  Does anyone know what causes this and what would I need to do to fix it?
Thanks in advance.
Offline JC
  • Back in the North.
Re: MOT explanation
« Reply #1 on: 23 February 2008, 13:50 »
Change the front discs is my first thought - but I await to be corrected .
And I am surprised the garage didnt explain how to fix it as its an advisory  :huh:
Offline Davo13
Re: MOT explanation
« Reply #2 on: 23 February 2008, 14:19 »
The garage I purchased the car from MOT'd it before I picked it up.
The other advisory was the front tyres, which the garage replaced.  My thought on the brake discs fading is that they will need replacing at some point but not straight away, as I'm sure that the garage would have replaced them, like they did with the tyres, if they needed it.
Thanks
Offline golf mk2 tornado red
  • same s**t just another day
Re: MOT explanation
« Reply #3 on: 23 February 2008, 18:54 »
more tha likly you will need new discs and pads. it means that your brakes are quivering but will only be slightly as hes advised it. if it was too bad you would beable to feel the brake pedal jumping abit like abs. or juddering at speeds when braking
the chances are there warped. this could be down to your brakes overheating. so if you fit new discs yourself ensure everything is free and easy
Offline [han]
  • Graphic Designer for Haribo
Re: MOT explanation
« Reply #4 on: 25 February 2008, 16:38 »
I'd ask the people who mot'd it :)
Offline N47HAN
Re: MOT explanation
« Reply #5 on: 25 February 2008, 17:44 »
i'd change the lot discs and pads better to be safe than sorry
