Author Topic: Forge intercooler  (Read 2853 times)
Offline RedRobin
Re: Forge intercooler
« Reply #10 on: 21 February 2008, 20:00 »
Very true, I was thinking more along the lines of if I got a K04 kit  :laugh:
....Hmm....I wouldn't do so without firstly being very confident and well informed about what else you need to do to a standard GTI engine.
Offline k4ith
« Reply #11 on: 21 February 2008, 20:05 »
....The oettinger intercooler is a replacement and not an addition like the Forge. I don't know which is better.
IIRC, the oettinger is actually from the S3 Audi. And 'their' intake is in fact a Carbonio re-badged as oettinger. Not saying anything wrong with that :cool:.
Oettinger ripping folk off imo.the s3 and Oet intercoolers are identical by all accounts.
the audi s3 intercooler will fit the ed30 as a direct replacement and is almost half the price of the Oet one, i think wolfbane has the Oet one fitted, you will also need pipe work from the S3  too, this is on my  shopping list after my brake upgrade
MKV Golf GTI Edition30, GIAC Pump&Race Map, AutoTech Fuel Pump, R32 Front Brakes, Dbilas Flo-master Intake, S3 Intercooler.ECS Dog Bone Insert.
MKII GTI 8v Tornado Red 88 - Das Projekt
Offline neg
« Reply #12 on: 21 February 2008, 22:33 »
I heard different, also the new Leon Cupra has a bigger IC and with the Ed30 being the same engine I would think it the same in those to.
Awesome also seem to think the Ed30 is slightly larger, sounded like they knew what they were talking about.
Peskarik
« Reply #13 on: 22 February 2008, 06:33 »
I talked to Wolfbane and he advised me to install IC and exhaust BEFORE remap, because he has done the other way round, and when they measured output it was 15hp lower due to too low pressure in the system. Also, he said that IC is very effective keeping temp constant at 22 degrees when they were running tests in-house.
So, if you don't get S3 IC thru Oettinger, where do you get it?
« Last Edit: 22 February 2008, 06:39 by Peskarik »
Offline k4ith
« Reply #14 on: 22 February 2008, 07:46 »
Direct from audi parts dept.£250 not sure if that incl vat
