Author Topic: brake questions  (Read 3679 times)
Offline Stu G
Re: brake questions
« Reply #10 on: 20 February 2008, 08:16 »
i did have bremobo grooved discs on mine. however the pads were getting a bit low and id warn the grooves out on the discs :P i got ebc drilled and grooved discs and green stuff pads and cost 300 quid to do front and rear. :) uprate them might as well if they need doing
Offline Mikester
  • Civic Type R
Re: brake questions
« Reply #11 on: 20 February 2008, 13:22 »
Of GSF
60205 - BRAKE DISC-VENTED 288mm B - G3 2.0 GTi 8V AGG Eng. / 2.0 16V ABF Eng. / 1.9 GT TDi AFN Eng. 97>
£27.50 each?
Are they any good?
Or are the bremo ones these ones?
60200F - BRAKE DISC-BREMBO'MAX' - G3 2.0 GTi / 16V >96
£36.50 each?
Are they drilled, or will they fit?
Which pads are obvious, just not sure about the discs.......
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: brake questions
« Reply #12 on: 20 February 2008, 13:34 »
I'd say go with the first set and use good pads such a Pagid, Forrodo, ect.
Offline Mikester
  • Civic Type R
Re: brake questions
« Reply #13 on: 20 February 2008, 13:55 »
Cheers, yeah, i will look up those brands and get some good pads.
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Re: brake questions
« Reply #14 on: 20 February 2008, 13:56 »
mine use to squeel when setting off from stationary, i wiped all calipers off and carriers and cleaned them up with file and sandpaper painted them while i was at it added a bit of grease where the pads slide on callipers and carriers. no more sqeelys he he
Offline oneblueleg
Re: brake questions
« Reply #15 on: 20 February 2008, 14:32 »
Cheers, i will check tomo, anyone suggest and good discs pads, i would like drilled or grooved, cus they look neat, but in the end, aslong as they stop good, and are not a million dollars.
Cheers again for all ur help
 :smiley:
Drilled I've seen advice no to, the undermine the disc and can cause cracks if overheated. As for discs specially, you get what you pay for... I've bought cheap discs from GSF for an E30 BMW and they warped within three months, never again. I'd buy those from VW, or take advice, but I reckon you probably get what you pay for with brakes.
Offline Stu G
Re: brake questions
« Reply #16 on: 20 February 2008, 14:36 »
its like anything. get what ya pay for. same with tyres shockers oil anything. rather spend that bit more get summat quality than have summat sh!t thats gunna f**k up within a month
Offline oneblueleg
Re: brake questions
« Reply #17 on: 20 February 2008, 14:47 »
Good advice... :wink:
Offline Mikester
  • Civic Type R
Re: brake questions
« Reply #18 on: 20 February 2008, 15:10 »
What should i go for then? lol. Link me up.
Offline oneblueleg
Re: brake questions
« Reply #19 on: 20 February 2008, 16:24 »
 :smiley:
Apologies for not being much help, I'm sure others know more than me, but I'd probably go with VW discs myself, not being a modded fan boy racer
